hood release broke
hood release broke
Under the hood main hood release cable snapped off at the end. What is the best way to fix. Can you get just a cable or have to buy the whole assembly. How does the hood release pull handle in the car attach to the cable? Never had to replace cables before so I am a bit confused. thanks
Received 6,937 Likes
2015 C2 of Year Finalist
Are you talking about the cable that attaches the left and right female hood latch. Or the one on the dash you pull to open the hood
It connects with one of these if you wan to see..
Part #462037
http://www.corvettecentral.com/?_ga=...470.1457209321
Part #462037
That cable is pressed into the handle. You can probably go to a local hard ware store and get parts to add length. Or buy a assembly
Received 2,126 Likes
Your fix may be related to what year car you have. I think there are differences. Most handles and the spring steel wire are one piece. The wire is crimped into the handle. Dennis
Repair
You can have a piece of piano wire (same gauge) brazed on.
I would grind some flats on the ends to give more of a lap joint, rather than a purely butt joint.
I saw this done successfully on a '57 pull cable.
