1957 steel valve covers - paint script silver?
I'm removing the aluminum finned valve covers that were a later addition and restore the original steel covers for my base engine '57. I'm not sure if my steel covers have original paint or not. The embossed script is now highlighted in silver.
Is this correct? Should I paint the text silver and if so, does it get Argent silver like the oil fill tube?
Rich
Received 6,527 Likes
C2 of Year Finalist (track prepared) 2019
However, just to add to the confusion, there has been posted here a photo of '59 engines in the factory which clearly do show painted script.
Smokd: If you want to hedge your bets, do this:
1. Paint the top of the valve cover silver.
2. Paint the whole valve cover engine orange, covering up the silver completely.
3. If ever you obtain compelling evidence the script should be silver, gently remove the engine orange from the script, exposing the silver paint underneath.
This will get you the neatest looking silver script possible.... if you need it.
Jim
You guys are awesome. All really good advise.
The car is really late. Nearly a '58. I'll do as Jim advises and hide silver under the orange.
BTW, I'm looking for an original oil fill cap as this unfortunately was not saved.
Thank you,
Chris
Thank you,
Chris
Received 1,857 Likes
Jim, that photo was taken at the Tarrytown, New York assembly plant - those are passenger car engines. '57-'61 Corvette base engine valve covers didn't have highlighted script.
Verne
Yes - Corvette and passenger car or truck engines each had different stamped suffix codes that defined their mechanical configuration (either one digit or two), and in some cases Flint and Tonawanda both built the same engine (usually a high-volume standard engine), and in some cases Flint was the sole supplier of a given engine (like solid-lifter performance engines, fuel-injection engines, Corvette engines, etc.). You will also find Canadian McKinnon Industries-built ("K") engines in some U.S. cars built in the northeastern plants, where you'd never find a McKinnon engine in a Midwest or west coast assembly plant. Most of the engines used in passenger cars and trucks built at Oshawa and Ste. Therese came from McKinnon, so not many were seen in the U.S.
2016 C1 of Year Finalist
John,
I recently ran across a 61 Corvette engine on which the casting number ended in 180.
I understand that it was a Tonawanda engine that was used in some Corvettes.
Did that engine have the plug above the timing chain cover?
I forgot to look.
Thanks,
Bruce B
I forgot to look.
Thanks,
Bruce B
Received 1,283 Likes
I have a 56 Belair, 3 owner, 76K original miles, engine never apart, original patina, and NEVER has an different color paint on the Chevrolet script.
The valve covers are clearly solid 56 Chevy red. The car is an August 56 built car.
I cannot track down the original source of this "script painted a different colors" for 1955-1957 Chevrolets. It is written lots of places, but no one seems to know the original source of the info.
Base motor steel valve covers on Corvettes are solid color.
The only block ever used in a Corvette that ended in "180" was the 3858180, used in a VERY small number of 64's or 65's to ensure machining compatibility between Flint and Tonawanda castings. Those trial 327 blocks were cast at Tonawanda, but all machining and assembly took place at Flint; they were all stamped with an "F" prefix on the pad, and had the plug above the timing cover that was unique to the Flint machining process.
that looks like the right cap. Now I can't remember if the base engine has the black paint or is zinc. The holes look right. Wonder how the filter material disappeared?
Did that decal survive all those years?
This cap, and the label are 100% original. The car has been packed away for many years.
I do not know what happened to the filter material, but putting in "back in" would not be that hard. The configuration is absolutely correct.
