Engine/transmission/differential combo for a smooth cruiser?
engine info
Also for a budget and TPI your going to have to figure out wiring to make the ECM work and redo cluster to talk to the ECM. I can't see that being cheap and keeping on a budget. And your still have a 35 year old out of date TPI that has almost zero help in the aftermarket world. Plus I don't think it will clear a SB hood so unless you already have a BB hood you can add that to the budget.
And unless you have auto-x in your future I can't see C4 suspension helping. Up to snuff stock mid year suspension will ride just as good as a C4 if not better. A C4 suspension is only great if your going to push it to its limits
Stan's Customs (04-21-2016)
