Engine/transmission/differential combo for a smooth cruiser?
Hi all,
I've got my dad's '66 I'm restoring and modding. I can work on and do just about anything on a car as I have been an aircraft mechanic for over 10 years. I'm not really a car guy though, I don't know what works best with what as far as engine, transmission, and differential combos go.
I don't want a fast car with a million HP, I want a good driving car I can enjoy and drive often.
So far my plans are to part out a C4, use its suspension, engine, and seats. Reason being is because I'm on a budget, but I also think the TPI would be a great cruiser.
My idea is to use the TPI with a 6 speed T56 and a dana 44 rear with 4.11 ratio?
Would that combo make me a good cruiser?
What would you guys recommend?
Received 6,943 Likes
2015 C2 of Year Finalist
Problem with TPI there is very limited market for that. Also they got good torque numbers but run out of steem quick. I think stock Dana 44 rears used a 3.42 so not sure how a 4.11 would work. For a budget a stock 327/300 4 speed with a 3.08 or 3.36 can't be beat. I like that motor more then a L98. Plus it's simple to work on and looks better. My 2 cents
Brad-SixTsix (04-13-2016)
I am very happy with the combination in my '67. I have the original 3.36 axle, a Tremec 5 spd with a 3.27 1st gear and .67 5th, and a ZZ4 crate engine with a few mods putting out around 400 hp and 400+ tq.
This gives me both great off the line performance with the 3.36 x 3.27 = 10.98 1st gear multiplication good up to 45 mph+, and great highway cruising with 70 mph in 5th gear being 2000 rpm. I get 22 mpg on a trip.
I don't think you want to set up your cruise rpm for much less than that 2k figure on a carburetored engine, so as to maintain responsiveness and the ability to pull smoothly in top gear.
Modern engines and systems are a different story - my '06 C6 will pull from 1000 rpm and get 31 mpg at 70 mph.
As for the engine, I sold it a few months back. The only thing original on it was the heads and valve cover, I sold the engine and turbo 350 for $400.
I just figure parting out a C4 will give me suspension, p.s., engine, and seats....Maybe I'll sell the engine for something else.
Would the T5 be a direct bolt in our would it require modifications?
From what I have read the T56 would require me to cut and raise the fwd tunnel area about an inch.
Also for a budget and TPI your going to have to figure out wiring to make the ECM work and redo cluster to talk to the ECM. I can't see that being cheap and keeping on a budget. And your still have a 35 year old out of date TPI that has almost zero help in the aftermarket world. Plus I don't think it will clear a SB hood so unless you already have a BB hood you can add that to the budget.
And unless you have auto-x in your future I can't see C4 suspension helping. Up to snuff stock mid year suspension will ride just as good as a C4 if not better. A C4 suspension is only great if your going to push it to its limits
Thanks for all the info. I am a newbie here and to C2 restoration so I know I have a lot to learn.
As to the C4, My thinking is that I can get one for around 2k, part it out and have an engine, suspension, p.s., seats for nearly nothing. I could sell the engine and buy something else, I have seen a few members on the forum with TPI's in their SB C2's though, they did have to trim out part of the X brace on the hood but they fit.
A p.s. conversion kit for a stock C2 is about 2k alone. Add an engine and costs to rebuild it and the stock suspension and I'm probably over 5k. For that cost I can have the C4 suspension installed and rebuilt. At least that's what I'm thinking.....
Maybe the T5 would be better, I think a six speed would be awesome but I'm not really sure if it's necessary. I have heard the L98 has good low end torque which is why I was thinking of the T56.
Hi all,
Our car has a big block, Tremec 5 speed and 370 rear end. 70 mph is just over 2krpm. We cruise for hours....
Gerry
I am not sure where you got 2K for a PS for a mid year. GM made thousands of them until 82. I know the later stuff will be metric and might look different then mid year ones but I can not see how they can not work.
for 2K your going to get one TIRED WORE out C4. seat covers and foam for a C4 is 1K so you just lost that one out. the rest of the parts you need are going to be just wore out on a 2K C4. I drive a 94 every day and mines got 160+K and its decent. you get a older one yet its going to be much worse shape. I can not see how you can come out ahead. I can run the numbers in my head and see its a lost cause. unless you get a low mile wreak that still as all the good parts you need. a stock L-98 motor would be a decent core to rebuild. but i can think of better starting points
And thanks for the T5 Verowing, makes more sense to me know, I think you've got me convinced.
This is why I haven't done anything major to the car or frame yet, obviously I need to learn more.....So, to all of you, if you were in my situation what would you do.
I want to get this car back on the road as soon as possible, but at the same time I want a car that I will enjoy driving. I drove the car years ago, the handling was so bad it scared the hell out of me. Drove it about a mile, turned around and I didn't even want to drive it after that.
Cool thanks again, looks like I've got more reading to do.
OTOH, if you were expecting it to feel like a modern Toyota Camry.....
Brad-SixTsix (04-14-2016)
I'm sure when I drove it everything was worn out, but if I ever drives like that again I would be very disappointed. I wish I could drive one with a stock suspension setup to see how it feels....I'm just afraid I'll get the car done and regret not doing certain things to it. I don't want to pull the body twice.
Brad-SixTsix (04-18-2016)
Well, after reading the advice you all gave me I decided to keep the suspension mostly stock, with any changes being only bolt on (monospring and rack and pinion steering).
Thanks for the info and advice, it saved me money, time, and probably a lot of frustration.
And as far as the engine goes I'll figure that one out when I get there, but will likely use the T5 with it...
Received 1,962 Likes
Tom
C4...TPI???...a 6 speed T56 requires tunnel mods
After much trial and error and more money than I want to remember spending, here is what I have found to work well in a NOM C2 that you want to drive:
I know you said you are on a budget...what I propose below probably would cost about $12K, but use it as a reference and it can be done a little at a time.
Engine/trans/rear combos with stock-sized tires:
1. Get a stroked Small Block (383/406) w/ aluminum heads...something with 450-475hp/tq...anything with more power tends to be a bit fussy in the lower/cruising rpm range. You can go big block which is also a ton of fun...just costs a bit more but totally cool.
2. Back it with a TKO600 (.82 overdrive) and a 4.11 rear that has the big block side yolks. The stroked motors give you gobs of low-end torque, which is what turns the wheels and the TKO600 5 speed with the 4.11s will make it rip AND it will cruise down the highway.
3. Dewitts radiator...if your current radiator is suspect/old.
Here are my suspension setup notes...it's what I did on two different cars.
1. Replace all front and rear associated suspension bushings...upper & lower control arms and trailing arm assemblies rebuilt by Bairs. Also replace, "top hat" rear crossmember bushings & rear gear housing snubber bushing.
2. Vette Brakes GRAND TOURING PLUS SUSPENSION KIT, 1963-77
Part#: 42001M
1963-77 Corvette. Includes: 330lb VBP Composite Monospring Kit, 460lb GT Front Coil Springs, HD 1.125" Front Anti-Sway Bar Kit, HD 750" Rear Anti-Sway Bar Kit, 4 Bilstein Sport Gas Shocks, & VBP Poly-Adjustable Rear Struts Rods.
***Ask Vette Brakes to provide #52000HD - VBP Smart Struts® Kit that comes with the Street and Slalom Kit. Its a better setup for the rear struts.
***Don't use the Bilsteins...sell them or tell vette brakes to keep them and pro rate the price.
3. Zip Corvette 63-82 QA1 Single Adjustable Shock Package. Set all shocks to +8 clicks.
4. Convert the steering to a Borgeson power steering kit.
I did all the disassembly and reassembly...that's it...easy peasy...just takes money and time...
You'll have a C2 that you will absolutely love to drive...it will be as fast as you want it to be, yet it will cruise effortlessly down the road.
Frank
Part#: 42001M
Frank
Dbl6gun (06-01-2016)
Received 1,843 Likes
Hi all,
