Help! Dropped my speedometer drive gear into the transmission
Okay, I will start by saying it was a dumb mistake... My speedometer hasn't worked since getting my 64 vert. I have done a complete frame off and rebuilt the gauges, etc. So I assumed it was just the plastics gear that attached to the end of the speedometer cable in the transmission. So I removed the old plastics drive gear and it was in fact pretty worn. But I made a knucklehead mistake of inserting the new plastic drive gear into the transmission before sliding it into the retainer bolt. Result- yup it fell into the tranny.... I've tried and tried to reach it but can't. Any suggestions?!?!
Okay, I will start by saying it was a dumb mistake... My speedometer has worked since getting my 64 vert. I have done a complete frame off and rebuilt the gauges, etc. So I assumed it was just the plastics gear that attached to the end of the speedometer cable in the transmission. So I removed the old plastics drive gear and it was in fact pretty worn. But I made a knucklehead mistake of inserting the new plastic drive gear into the transmission before sliding it into the retainer bolt. Result- yup it fell into the tranny.... I've tried and tried to reach it but can't. Any suggestions?!?!
2021 C1 of the Year Finalist - Modified
1st step is to get a mirror and a light try to spot it. Hopefully it didn't go far, even better is one of those inspection camera's. If you can see it you MIGHT be able to get it out.
Received 2,127 Likes
I would think by suck out all the gear oil it should be easier to see/grab. I'm not sure about this next idea, can't you take the shifter side plate off and get access? Try to find a flexible claw tool at a parts place. Dennis
Originally Posted by 1955 copper
For get it buy a new one ,it ant going to hurt leaving it there unless you want to go through the trouble pulling the tail housing off.
Thanks!!
Thanks for the response!
Only thing I didn't try was removing the side access panel because I didn't think it would work.
Unless someone tells me it will hurt something I am just going to get another plastic gear and replace it leaving the new one I dropped in the tranny.
Thanks for the suggestions.
Removing the side cover won't help because the speedo-drive gears are in the aft compartment.
Originally Posted by 59BlueSilver
it isn't going to hurt anything!
This community is an awesome support network!
Your not the first person to have this happen, as others have stated put a new one in.
Lesson learned!
Way back when we were assembling our dragster motor, we looked for the cap for the ultra rev lubricant. it was no where in site, of course we were concerned that it might be in the engine but what the hell, what can a small cap do?
The next time we looked at the bearings after the race, we found it. It was all melted and sticking to all the bearings!
I'm sure that the gears in the trans will make many little pieces and might even help quiet the slop in the gears.
I dropped one in a muncie three years ago and drove it for a year before replacing it with a TKO. I separated the main and tail case and there it was lying unscathed in the bottom of the tailcase. I placed it back in the parts bin.
Did the same thing. Went fishing and got it first try, I ran to buy a lottery ticket, but my luck had run out.
Thanks for the affirmation that I'm not the only person who had this happen to them! I was afraid I was going to tear the transmission apart!! You guys rock!
Don't take the tranny apart. Leave it ! There's not much happening in the rear tailhousing. It's not going to get chewed up.
Cheers!
