Telltale and High Beam indicators
Well, after numerous searches I haven't been able to locate a thread with this specific issue so I thought maybe you all could help...
My Telltale light and High Beam light indicators were on continuously if my headlights were on. All the lights, switches and instruments on the cars work correctly otherwise. The Telltale switches were disconnected which was part of the issue but I got them working which brings us to the current situation...the Telltale switches now work, but make the high beam light extinguish and the Telltale light keeps flashing no matter what I do. Switching the headlights hi/low works the lights, but nothing on the dash...what do you think?? I thought the sockets may be swapped on the dash back, but since the Telltale flashes correctly, that might not be the case...
Hope this makes sense...
I'm sure a couple of wires are incorrectly hooked up, but I really suck with electrical... :crazy
It's been like this since I got the car a few years ago but I've just lived with it until now. Thanks for any help!!
Wild guess based on speculation. Maybe a flashing bulb (like the one in the tell tale and brake positions) was put in where the bright indicator goes and then the two plugs switched so that you now have your tell tale light in the bright spot without a flashing bulb and ...... well you get the idea.
SonnyAK (04-19-2016)
The wire color going to the high beam indicator should be light green and not a flasher. The two wires to the tell tale should be gray/black and light blue with a flasher bulb.
It does go off when the headlights are rotated and the Telltale switches engaged...but the Telltale doesn't go off if the headlights are on low beam, like you think it would if the wires were just switched...
Looking behind the dash (from below). Looks like the 2 wire holder for the Telltale is in the High Beam spot and vice versa, so that's an issue, but the odd thing is that the High Beam doesn't actually flash, like you think it would if switched...
They're supposed to be two different kinds of bulbs, I'm not sure what would happen. Also verify the brake warning light is in the correct spot with correct bulb. You may have the bulbs in the correct spot, but in the wrong sockets. Again not following a diagram, just speculation.
I have NEVER put a 'flashing bulb' in the HIGH beam indicator socket and see what it does. I guess all it would do it flash.
Verifying your parking brake warning light is something I would do...as previously mentioned.
IF the problem still persists....then a problem in the wiring or a component is failing causing a problem..and that can be determined once we get past a few unknowns.
It also would be wise to have a wiring diagram....if you do not have one already.
DUB
I DO KNOW that IF you do not have the correct 'flashing' bulbs and use regular bulbs...the lights will work fine.
DUB
DUB
There's no wire running to the brake light socket, and the switch isn't hooked up either right now. I'm also back in Alaska now (car is in KY) and won't get back down there for a few months
At some point I'll dig into it and figure out what the issue is - probably a combination of bulbs and wires in the wrong spots. Fortunately this is the biggest issue I have going with the car right now, so I'm pretty lucky!
Thanks for the help and ideas!
