63/64 dipstick seal
63/64 dipstick seal
Is there available a new replacement seal for the 63/64 dipstick? I don't seem to be able to find anything but the whole stick. I really just need/want the seal as mine is falling apart from age!
I've had very good luck with o-rings. Pick a thickness that gives just a bit if friction between the dipstick tube and the oil pan tube. Its ok if the o-ring has to be stretched just a little to fit over the dipstick tube. The bead on the dipstick tube will keep the o-ring from sliding out of the gap between the tubes when they are assembled.
A piece of duct tape pulled over the handle would work too, for free. But he asked about where to find the replacement cap/seal. I was mistaken, it is Paragon part no. 9274 and you write the part in the notes. $2.
all you need.
all you need.
pop23235 (04-19-2016)
