58 - Modification of clutch rod
I have read about every post regarding the poor design of the mounting of the clutch rod to the Z-bar and the only solution that made sense to me was the one that vetrod62 (Jim) came up with.
So, I bit the bullet and cut my clutch rod at the point where I would have the same distance (but some adjustment) with the Heim joint.
I then threaded the rod with at 7/16x20 and installed the summit racing Heim joint which I found from a post by FTF (Frank).
http://www.summitracing.com/parts/sum-msf7
Manufacturer's Part Number: SUM-MSF7
I didn't want to modify the z-bar...so I left the pressed on metal but obviously had to remove the bushing cause the Heim joint is a lot thicker.
I used a 5/8" bolt (total bolt length 2 1/4") with no threads at the head, and this fit nicely into the Heim joint. I took a nut, threaded it on the bolt and then grinded it down to fit inside z-bar to keep the 5/8" bolt from wiggling.
I then removed the nut, put a washer on the bolt, then the grinded down nut (bushing), cinched it down...slide it into the Heim joint, then the z-bar, then another washer then a lock washer, then the nut. Works great.
BTW...when I went to tighten up my original bolt...it snapped and this is what made me go this route.
Should last forever.
Received 1,962 Likes
Tom...I was under the car last night installing that anti-rattle spring...WHAT A PITA!!! I spent a good hour trying to get it on...then once I got it on, I forgot about the leather dust cover...so I took it off. Then I tried to mount the spring so the front end of it would go through the hole from top to bottom on the rod. I think I spent 3 hours on this.
Yours look over the top!
Good looking work! I went the metal bushing route on my 57, based on FTF's threads, and has been working well. My only concern is that metal bushing in z bar has some play in it (up/down) when all bolted together.
