Best Fuel Sending Unit ?
I may have to replace my sending unit. What brand or vendor sells the most accurate one...as accurate as a corvette part can get....
jack
jack
As much as Jack drives his car...
I don't think he could wait that long for it to be fixed...
Jack,
I would just get one form a Corvette parts supplier and install it. You are aware that the sending unit gauge basically goes from 0 ohms to 90 ohms. SO if it is off a little bit is not a big deal...not like you can not go back and look into the gas tank.
I can write this. I recently replaced the fuel tank, sending unit, fuel line on the frame and fuel pump on a 1967 427. The gas tank was the correct stamped fuel tank and it leaked where they weld the two halves together...so it had at least half a tank of fuel in it......so they sent me another. When I pulled out the fuel tank and sending unit....the float rod and float came out of the sending unit and was inside the gas tank. WHICH MADE SENSE due to the notch in the sending unit gauge has a notch in it so it can be installed..and with the fuel tank being half full...that is how the rod worked out and came out. SO...when I went to re-install the sending unit...I took some really fine wire and wired the rod to the plastic arm that DOES have tension clips to hold the rod in place. These clips appeared to be OK...but I was NOT going to take any chances and have to pull the sending unit again for a this problem.
AND I BELIEVE the problem has been corrected...but about 10 years ago I got a new sending unit and installed it on a 1964 convertible and when I looked into the gas tank..the actual float was floating IN the gas half way and was NOT floating on top of it. And when I removed it and weighed it and compared it to the original float...it weighed twice as much. So I installed the actual float and corrected the problem.
NOW....when I get a sending unit...I have a bucket of gas and set the float in it and see if it floats or sinks....and so far...they have been floating.
DUB
DUB
Jackfit (04-24-2016)
Larry
ohiovet (04-26-2016)
Received 1,962 Likes
Here's another source - it's amazing what these guys have:
http://www.rockauto.com/en/catalog/c...ding+unit,4436
I bought a reman'd power steering pump from them last fall - its looks perfect and works even better! Good luck my friend!
Tom
Received 6,929 Likes
2015 C2 of Year Finalist
Jack,
DUB
DUB
Jack, you got the best advise first. You can buy a replacement which will / may work for a time, but in the long run your original rebuilt is best. Speaking from experience here. John Wolf does an excellent job and can also explain to you why all the reproduction units currently available WILL fail even if they don't leak. Ask me how I know. Pilot Dan
Hi Jack,
Tom
Tom
with DUB. Buy it from a corvette vendor then do the ohms and float test prior to installation.
The only other thing I can add is that after I installed an aftermarket sender on my car I found that it was very inaccurate and yes, I did the above tests. The gauge always showed WAY less fuel than was actually in the tank, like almost half a tank MORE!
Better that, than the other way around but, it bothered me. So I removed it and bent the float rod downward about an inch. Now instead of almost a half a tank off it shows that I have about an eighth to a quarter more fuel than I actually have (wish I would have bent it a little more) but, close enough.
Gary
Gary
I went thru the fuel-sender search several years ago for my 67. Two units from Zip were very inaccurate, reading much lower than the gas level in the tank. Several people said to buy a unit from Fargo, so I did, but it reads the same as the two Zip units. I wish I had saved my original fuel sender unit and had it rebuilt. When I fill the tank to absolutely full and drive 25 or 30 miles the dash gauge reads half empty. When the dash gauge reads Empty I have 8-10 gallons left. Just have to live with it.
Gary
Gary
I do not even attempt to try to keep track of who makes what any longer. It is pointless. With many companies allowing the 'bean counters' to get involved in making them more money...so it is a guessing game when and IF things change.
I know of those parts that I have had problems with and found that sometimes there is more than one manufacturer....and I switch to them and hope for the best. But I DO KNOW that some companies...for example...offer the vacuum headlight/wiper door actuator relay. SOME of them are total CRAP...while others are really good. So...for me..I have certain companies that I trust...and others that I have to hold my breath and hope for the best because that is all there is out there.
So...me trying to call around and find who buys what from who... and who makes it... is a waste of my time UNLESS I get burned by it.
As for this sending unit discussion.....I would get them from my Corvette vendor...and not even try to get them from a local auto parts house....because in many cases.....they charge more...or I have to wait days for it to come in.
But to each his/her own...get it from where ever you choose....or send it out for rebuilding.
AND YES...I also have had to 'dial-in' a sending unit to get it to read correctly...even though the sending unit range is correct...the arm may need to be bent to read correctly when the tank is in the car...and this 'dialing-in' can be done so I can let the customer know that when the needle is on 'E"...they have 'X' amount of fuel left in the tank.....because I also do this on the Corvettes that have the "LOW FUEL" light....where there is a specific amount of fuel in the tank when the LOW FUEL light begins to glow.
DUB
DUB
I think that the MAIN point DUB (and I) were trying to make is that, whomever or wherever they're purchased from, they need to be scrutinized before installation and, even then such as in my case, be removed, adjusted and re-installed.
Gary
I nor DUB didn't say that it COULDN'T be had at a parts store. As far as I'm concerned they're ALL a crap shoot whomever they're purchased from.
I think that the MAIN point DUB (and I) were trying to make is that wherever or whomever they're purchased they need to be scrutinized before installation and, even then, such as in my case, be removed, adjusted and re-installed.
Gary
Gary
