Odd engine serial number--what engine is this?
Old 04-26-2016, 10:45 AM
Mike6811
Mike6811's Avatar
Default Odd engine serial number--what engine is this?
My '60 has motor casting number 3858180 which the Corvette Black Book states is a 1965 327, but also notes it's a "limited use" motor but not explaining what that means. Its serial number is odd--TI 029 FAH. Can anyone tell me the horsepower, etc., and where to find info? Tried many online engine decoder sites, but no luck.
________________________________________
"Back to the wall goes Berra, it is...over the fence, homerun, the Pirates win!!"
Old 04-26-2016, 11:13 AM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
Closest I can come is FA used in 1969 on 327's. Sometimes an H is added to a two letter suffix indicating it came with a Holley carburetor however.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-5.php
Block lists as a 64-67 327, 250-300hp. so it probably wouldn't fit the above suffix.
http://www.nastyz28.com/sbchevy/sblock.php
Good luck... GUSTO
Old 04-26-2016, 11:32 AM
Chuck Gongloff
Support Corvetteforum!
Chuck Gongloff's Avatar
T= Tonawanda NY engine plant
10 29 = Oct 29 assembly date
I didn't check the FA part of the assembly suffix, but often times an H was added to indicate Holley carburetor.
Old 04-26-2016, 11:37 AM
gbvette62
gbvette62's Avatar
Received 2,029 Likes on 1,315 Posts
Most Chevrolet engines were made at either Flint MI or Tonawanda NY.
Corvette small blocks were all cast and assembled at the Flint engine plant. The exception was for a couple weeks in 65, when there was a strike at the Flint foundry. A few Tonawanda 327 blocks were sent to Flint for machining and assembly. These are the 180 blocks that are listed as "limited use".
Blocks assembled at Flint prior to 67, can be identified by a "F" prefix on the stamp pad, while Tonawanda used a "T" prefix. The limited use 180 blocks had a "F" prefix, since they were cast at Tonawanda, but assembled at Flint.
The T prefix in your engine stamping, identify's your engine as a passenger car 327, because it was assembled at Tonawanda. I029 is the engine's assembly date, October 29th (I was often substituted for a 1). The 180 was used for both 250 and 300 horse passenger car 327's, from 64-67.
The FAH I don't know about. There were no suffix codes that began with an "F", during the time the 180 block was in use. About the closest thing I can find is "EA", which is a 65 327/250 with a manual trans in Nova's and Chevelle's. I agree with the others here about an "H" indicating a Holley carb, but the 327/250 came with a Carter WCFB?
What's the casting date on the back of the block?
Old 04-26-2016, 12:37 PM
emccomas
emccomas's Avatar
Received 1,283 Likes on 732 Posts
Double check the numbers and also check the casting date of the block.
I suspect that you will find a casting date that works for the 1966 model year, and a engine code something like TI029 EAH.
If so, that is a 1966 327, 275 hp installed in a Chevelle or El Camino, and equipped with a Holly carburetor.
Regarding the carburetor type being coded into the engine code, 1966 is the only year that I can confirm that was done.
It had to do with what intake manifold was installed on the engine.
If it really is TI029 FAH, then I am lost.
Old 04-26-2016, 01:34 PM
1COOL60
1COOL60's Avatar
Location: Emporia, pay no attention to that man behind the curtain, KS
I don't know about Chevelle and Nova 327's, but my parents bought a new '62 Belair with a 250HP 327. It was equipped with a Rochester carburetor.
Old 04-26-2016, 02:31 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
If it was in a car, it should have a 7-8 serial number derivative also, not just the engine ID and assy date on the stamp pad.
Limited use may have been for a boat, or stationary use like a generator or some other odd usage.
Doug
Old 04-26-2016, 03:04 PM
Mike6811
Mike6811's Avatar
Many thanks for all who responded. Seems I might have a mild 327 installed. What can I do to the motor to give it the performance of my '66 327/300?
________________________________________ ____________
Old 04-26-2016, 06:34 PM
DansYellow66
DansYellow66's Avatar
Received 2,620 Likes on 1,952 Posts
Well, originally it was a 283 so even a mild 327 isn't bad. I don't think there was a lot of difference between the 327/275 and the 327/300 motors. I thought most of the difference was which car the basic motor was installed in and exhaust system restriction.
Old 04-26-2016, 07:15 PM
emccomas
emccomas's Avatar
Doug
Not all engines had VIN derivatives during this time frame.
Legislation forced VIN derivatives on all major components (engine / transmission) by 1969, but VIN derivatives were not put on a lot of low to medium performance engines through the mid 1960s.
Old 04-26-2016, 07:18 PM
emccomas
emccomas's Avatar
I am still thinking that the FAH is really an EAH, which would make sense. Please double check it.
Old 04-26-2016, 07:20 PM
PAmotorman
PAmotorman's Avatar
what is the LIST number on the carb because if it is the original carb to the engine I can tell you what engine the carb is from. the LIST number is on the front of the choke housing
Old 04-27-2016, 08:42 AM
GUSTO14
GUSTO14's Avatar
FYI...
GUSTO
Old 04-27-2016, 10:19 AM
MikeM
MikeM's Avatar
Received 1,843 Likes on 1,398 Posts
Pass cars used the Rochester, Corvettes used the Carter.
Old 04-27-2016, 10:28 AM
MikeM
MikeM's Avatar
Does this mean it currently doesn't run as good?
If you really have a 327 block, the best place to start would be to have the 327/300 heads and carburetor.
What is on your engine now?
The '60 uses a 2" exhaust while the '66 used 2 1/2" pipes and mufflers but I don't think that will hurt you.
For the nit pickers............. Yeah, I know the '66 used 2" manifolds with 2 1/2" pipes.
Old 04-27-2016, 11:59 AM
GTOguy
GTOguy's Avatar
Received 3,443 Likes on 2,113 Posts
If it's a '66 block, it will have a boss for mounting the road draft tube at the rear of the block, A '69 block won't have this.
Old 04-27-2016, 12:09 PM
W Guy
W Guy's Avatar
Mike,
A lot of Pass cars also used the WCFB. The Rochester was more common though.
Verne
To Odd engine serial number--what engine is this?
Old 04-27-2016, 02:37 PM
MikeM
MikeM's Avatar
Originally Posted by W Guy
Mike,
Verne
Yes, true.
Old 04-27-2016, 07:17 PM
Mike6811
Mike6811's Avatar
Right now it has the 2x4 setup, but in a bad state of tune (just bought the car). But I'm concerned that even if I put an Edelbrock Performer and single 600 Edelbrock carb it still might not have the pep of the '66. Thinking of replacing the motor with a Crate 350/325 HP 291P while changing the radiator and adding Vintage Air.
Old 04-27-2016, 07:56 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
Bill
Quick Reply: Odd engine serial number--what engine is this?
