Where are the LT1 (C7) restomod builds?
The LT1 engine has been available approximately 2 years, and yet I've only seen a couple of restomod builds using it, including one that was built by GM to market it.
http://www.superchevy.com/features/1...ette-stingray/
http://www.corvetteblogger.com/2015/...-indy-auction/
Lots of high dollar restomods are being built, and they mostly all have the LS3. A new crate and controller for the LT1 is about $3k more than the LS3, but that is a drop in the bucket for some of these builds, which are generally premised on having the latest and greatest drivetrains. They are available in both wet sump and dry sump configurations. What gives? Would a LT1 install be that much more difficult than a LS3 install?
Platinum Supporting Vendor
Justin
I was contemplating the LT1 for my build and I agree with Justin. The LS3 has so many extras that the cost to replicate with an LT1 would far surpass the $3k difference in engines. I ended going with the LS3 480 HP. It is still considered a 'latest technology' engine but not an LSA or LT1.
Honestly, if I had a spare few hundred thousand laying around and was buying a restomod, I would look more at the craftsmanship of the build (body, interior, engine bay etc). I would not say 'oh, this only has an LS3, I really wanted an LT1. Kind of like buying a house with a pool. Not a deal breaker but a nice perk. I think there are more people buying with this thinking (my opinion). Now I would, however, buy an LS3 or LT1 vs a carbureted 350 from 1965.
The LT1 came to being by increasing the emissions/fuel economy requirements....it's increased costs aren't worth it over the LS3 motor. The LS3 is more easily modified and cheaper!
I like the idea of Direct Injection, but that's the only real upgrade. Haven't followed it's development, but if there was no improvement to intake an exhaust air flow as with the LS7 and L3, not worth the difference.
I'll wait for the High Reving V6's as I just know I'll make use of those higher RPM they will have with more room in engine bay to boot....LOL
C2 of Year Finalist (performance mods) 2019
The LT1 and other direct injected engines are having real problems with valve coking issues. Do a search in the C7 forum or just google valve coking and you will find all the manufacturers are dealing with this problem. From what I have seen there doesn't appear to be an easy fix. There are videos showing intake manifold removal and blasting the intake valves with walnut shells. It's not a cheap fix.
If I was building a restomod I would go with an LS3. This is a proven engine offered in 3 hp versions.
Live well,
SJW
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Has the aftermarket caught up with the LS in terms of alternate oil pans and front drive accessories?
The LSA transplants are becoming quite common these days.
If you need a shallow oil pan as C2 does, all you need to do is order the correct GM part numbers that have the corvette pan installed on them. Did this with both 430HP & 480HP engine in 2 of my cars. 3rd is LS7 which has shallow dry sump pan. Lot cheaper than having to modify the deep pan part numbered engines.
I'm contemplating using the LT1 in my '59. Aftermarket parts to make it all work have recently been made available such as fuel pump system, accessory drive with Power steering and A/C up high, motor mounts, headers, and some top side intake manifold and valve covers. Up until this stuff was readily available off the shelf, the few restomods you have seen had a lot of figuring out to do on them to source these components.
The LT1 is the "latest and greatest" which trumps all logic regarding horse power vs. $$. This with the lower end torque are advantages of the LT1, but will cost you ~$5K+ more than a 480 HP LS3. The cylinder cut out system is disabled on the crate LT1, so no fuel savings there.
Decisions, Decisions....
I'm envious of you gentlemen that have the skill set to build these restomods. It challenged all my ability and patience just to change out my rear spring and strut rods. I was fortunate to meet Poorhousenext last year at fall corvette expo and loved his car and new build he is working on. I really enjoy reading about your builds.
The "real problem" is too many **** obsessive compulsive people who see pictures of some crud on a valve and freak out and start long useless threads on car forums.
Have you ever looked at intake valves on carburetted or port injected motors? Even ones that use top tier gas?
They are FAR filthier, with more buildup than you get from some oil pullover on a DI engine after the same amount of miles. If some one still isn't convinced, put a secondary catch can on the PCV line to the intake to ease teh worry..
Doug
