Best thing I've given my car, in years
I had Lars rebuild my distributor, a couple months ago. I installed the distributor and set the timing per Lars instructions. I can't believe the difference in how the engine performs. The engine starts better, the acceleration improvement is pronominal and getting the car moving with the 3.08 rear is much easier. Feels like a whole new car.
Many thanks Lars, great job.
But, I thought I heard on here that he wasn't rebuilding distributors anymore - I sure hope that's not the case
Larry
Received 1,843 Likes
The factory guys were not dummies. They had to tune for good and bad gasoline. You can bet they knew what was best. No secrets here.
Guys..... you made me jealous. I have been trying to get my stock L79 dist to Lars for 2 years now. I cannot get the distributor out. It moves up a 1/2 inch rotates left and right but I cannot for the life of me get it out. Yes the hold down bolt is off, tach cable off, shielding off, but I cannot raise it more than 1/2. Any suggestions. Car is all stock as far as I know.
Received 1,122 Likes
Lift the distributor as high as you can get and spray some carburetor cleaner down the housing. Keep moving distributor up and down and back and forth and repeat spraying carburetor cleaner and it will come out.
Joe
Joe
Either have the car at TDC (compression stroke) when removing the dizzy or else mark with blue tape on a valve cover or elsewhere in two places. Where the vacuum can nipple points and where the rotor points and DON'T bump the engine...then you can reinstall it close to the right position..
As to tweaking the advance curve, there is almost nothing you can do any more cheaply and easily to give yourself a 'seat of the pants' performance improvement. Carefully modifying the lazy, conservative, one-size-fits-all factory advance curve will not cause the polar ice caps to melt
