Ididit steering column wiring problem
I just installed an Ididit steering column in my 62. I have the wiring package for a C1, I can make the Horn work, the emergency flashers work but I cannot figure out how to wire the directional signals.
I contacted Ididit technical support, I sent pictures, they said they did not think it was original wiring. It is original wiring according to the 62 Corvette wiring diagrams.
Has anyone on the forum installed the Ididit column and how did you wire it. Any help would certainly be appreciated.
St. Jude Donor '05, '09, '15
Tom
Received 6,928 Likes
2015 C2 of Year Finalist
How do you have 4 way flashers. That wasn't a option until 65 and became standard in 67. It should be very simple to match wire colors
St. Jude Donor '07
Bill
2023 Corvette of the Year Finalist - Modified
2022 C1 of the Year Winner - Modified
C1 of Year Finalist (performance mods) 2019
I've got an Ididit in my 61 - but
I've also got a Classic Auto Wire harness to connect to it, but it shows the pinouts for the turn signals.
Let me know if you think they would help.
Ironheadvette
Ironheadvette
I don't know how to post pictures on this forum. If you can send me an Email I can get them to you.
marty69003@aol.com
marty69003@aol.com
Can you send me pictures of how you wired your 62? You can send direct to me at:
marty69003@aol.com
Thanks,
Marty
Pics from 62 corvette nut. The connectors are not the same as my midyear so I am not much help on the body side harness. Maybe they will help someone else, help him solve his problem.
Tom
Tom
Watch the horn too
I also discovered my original Steering wheel hub (all metal) has a tendency to short out on the two tabs wrapping the horn rings. Causes the horn to honk at the worst times. I just put some gasket material in between it and the hub.
St. Jude Donor '07
I've slept a couple of times since responding...
do you have the mating pigtail, as shown in my pictures, to the connector coming out of the column? if so, the wires are color coded, and with the Ididit directions, should be a slamdunk in getting it to work correctly.
Bill
Bill
Bill
Bill
Thanks for the pictures I think they'll be a help after I determined if the turn signal switch is operating properly.
Marty
