Dip stick tube question (I know, really exciting)
Old 04-30-2016, 06:12 PM
Jeffrey67
Jeffrey67's Avatar
Default Dip stick tube question (I know, really exciting)
I have a 67 327/350. While checking the oil, I pulled out my dipstick tube along with my dipstick. I pushed it back in, but it rotates, and I'm afraid it might come out while driving. Am I missing a bracket? Or will a new one fit more tightly??
Old 04-30-2016, 06:39 PM
65GGvert
65GGvert's Avatar
Received 3,205 Likes on 2,297 Posts
They are a press fit, tapped in. Usually they are so tight you have to chill the end a little to get it started, then tap it in. I think I'd just expand the bottom a little and put it back
Old 04-30-2016, 06:45 PM
Canuck62
Canuck62's Avatar
I had the same problem awhile back,,, I did the same as 65GGvert suggested,, i flared the end a tiny bit,, stuck it in the freezer then tapped it back in with a block of wood ,,, so far so good
Old 04-30-2016, 07:51 PM
fyreline
Support Corvetteforum!
fyreline's Avatar
Received 1,266 Likes on 507 Posts
2021 C1 of the Year Winner - Unmodified
2020 C1 of the Year Finalist - Unmodified
2016 C1 of the Year Finalist
I had this same issue with my '62 327/300. Put the dipstick tube in the freezer, tapped it back in with a wooden block while applying a bit of Loctite blue. Been fine for over a year now. Good luck.
To Dip stick tube question (I know, really exciting)
Quick Reply: Dip stick tube question (I know, really exciting)
