Steering column squeek
Received 2,130 Likes
2015 C2 of the Year Finalist
A friend asked me about a squeaking steering column when turning the wheel on his 64 vert. He insists he hears it inside. You guys have any idea?
Dan
Dan
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
I've also been told by my wife that she hears a squeak coming from the rear of the car but if I can't hear it, it doesn't exist. As my hearing worsens, I won't notice the steering column squeak either.
Tracking down all the squeaks and rattles in these old cars is like playing whack-a-mole.
-- Steve
Yessir, upper bearing. You can fix that while the column is still mounted in the car. If you pull the column out you'll find problems that you never expected i.e. worn shaft at the lower bearing, etc.
Ray
Ray
Check both upper and lower bearings. That squeak may be a worn bearing . I've rebuilt columns that were so worn the lower bearing wore a grove half way through the shaft. If me I would check the column bearings especially if it was never rebuilt .
