Door lock cylinders
Door lock cylinders
Any tips or tricks for putting retainers on door lock cylinders on a 66. Having trouble keeping cylinder and rubber gasket in place while trying to drive the retainer on. Retainer very tight. Thank you for any help.
Someone pushing on outside while you put retainer on
Jack
nasteve (05-01-2016)
If you're talking about the U-shaped flat steel clips there is no 'silver bullet'.
I start the edge under the door lock cylinder and using a brake spoon or other such tool push forward on the clip. It sometimes helps to push the concave part of the clip towards the door with your other hand to make it a bit flatter while you push...
Nasteve - I believe the reason you're running into difficulty driving on the inside clips is due to those gaskets. If I remember correctly, they were never used by the factory.
Mike T - Prescott AZ
Received 6,943 Likes
2015 C2 of Year Finalist
DUB
