little help , street shop chassis 66 conv tire size
Have a Street shop chassis with C7 suspension and stock brakes. Anybody know what rim size and back space would work best . I want to keep the wheel houses as small as possible . I know this does not make sense but that is what my customer wants . thanks
I think no one has responded because no one on this forum has any experience with the combination you are working with. The chassis builder should be able to give you the hub to hub width and you can measure the inner and outer width of the wheel well you are working with. From there its simple addition and subtraction.
My understanding is the C6 and C7 suspension is identical, but it comes down to what the chassis builder is fabricating. Hope this helps.
