1964 Corvette engine numbers help
Hey guys I have some engine numbers I need help with. I believe the engine to be a 327. The large number on the back of the block on driver side is 3892657 and the number on the front right of block is VI0I4Hf or V1014HF. Any help is appreciated. Thanks.
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
That's a 67 block but it was used in corvette, camaro and truck applications. Corvette used HE suffix but not HF in 67. The 1014 is October 14, the engine assembly date. If there's no VIN, it's probably an over the counter block.
Received 1,857 Likes
That same casting (3892657) was used in cars, trucks, and Corvettes in 1967, but each application was different; the "HF" suffix was only used as a 275hp passenger car engine in 1967, so the block you have is not from a "Corvette engine".
That's kinda what I thought. Thanks you!
Received 1,391 Likes
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
And typically, if a '67 HF suffix, it indicated 4 barrel carb, air injection reactor, and Powerglide transmission in a GM passenger car.
