Starting takes to long
#41
Thanks Frankie
The photo I posted is an old one, before I changed the carb setup back to progressive after your advice in a previous post.
Thanks also for the other leads on retrofitting a choke - I'll follow those up.
#42
St. Jude Donor '07
personally, I would convert to an electric choke; if possible for that carburetor... and do away with all that other 'stuff'...
Bill
Bill
#43
Absofreakinlutely! Put the antediluvian relics in a box on a high shelf and save them for the flight judging fields. In the real world they changed over to electrics for a reason, plus it's cheap and easy to do.
#44
Re-fitting a choke may not be as easy as first thought.
I don't have a choke assembly at all (no housing, valve, lever, linkages, etc) and am not sure whether more readily available parts for a Corvette 2x4 Carter WCFB will fit my Chrysler '56-'58 Carter WCFB setup?
Anybody know whether a kit like this - http://www.ebay.com.au/itm/1956-61-C...kAAOSwLa9UW3~Z woulso fit my primary carb?
#45
That rear carb is a 6-1310 '56-'58 rear carb off a Chrysler dual quad setup...it appears to be a high choke carb and those eBay parts should work -- provided the choke cover has the thermostatic spring and the housing has the piston. You might want to take a shot at getting it but I wouldn't chase the bids too high... You would want to buy a repro hot air tube that goes to the choke housing.... A linkage rod or two is all else you'll need and they are all around for sale..(you can make them too).
Now - having said all of that...you could always just get a choke valve (like in the ad) somewhere and make a manual choke with a push/pull button at the dash which controls a cable to the choke. Kits for this are about $10...
Not pretty, but simple, old school -- and foolproof.
If you just want easy starts on cold days without a lot of the original 'magic' that's failure-prone...that's certainly an option.
May want to start your own thread though - we've hijacked this one from rtruman...
#46
You appear to have the high choke carb and those eBay parts should work -- provided the choke cover has the spring and the housing has the piston.
twice ,other than the adjustment I will be happy .
#47
Hang in there and work through the issues and you'll have a fine running carb. I hate to see people get frustrated and swap on an Edelbrock carb which is nothing but a clone of the AFB they already had
rtruman (05-25-2016)
