Tubing bender
Tubing bender
I need to bend some 1/2" thinwall aluminum tubing (fuel line tubing) for a project that I am working on. Any recommendations on a good bender to use?
Thanks,
Charles
Thanks,
Charles
Charles, my tubing benders go up to 5/8", if I need to bend up to 1 inch I use conduit benders. I do a/c work on old cars with rear mounted units and some of them use 5/8 and 3/4 suction lines. Bill
Imperial tubing benders......what the pros and instrument guys use for 1/2 inch tubing. Buy a used one from Ebay.
Larry
EDIT: This is an example for you. http://www.ebay.com/itm/IMPERIAL-OD-...sAAOSwstxU87tr
As Jim says, this is one of the best. I have a number of various sizes in my garage. If you get good/used they are affordable.
Larry
Received 6,529 Likes
C2 of Year Finalist (track prepared) 2019
Charles,
If Imperial makes a bender which will do 1/2" tubing, I'd think that's the brand to buy.
I use Imperial benders any time I need to make a brake, vacuum or fuel line. The results are consistently high quality.
Jim
Jim
Advice sounds like it comes from a Mechanical/Construction Engineer with hands-on experience.
Larry
St. Jude Donor '07
now, why don't I recognize you (I have sleep a few times since then, and I suspect a few 'senior moments' haven't helped...)
thanks
Bill
Location: Las Vegas - Just stop perpetuating myths please.
Amazon sells a Aircraft Tool Supply/Imperial bender for soft tubing up to 1/2". The 370FH is $52 does 3 sizes but only thin wall steel, stainless and soft alum/copper. Not many 1/2" benders out there for tubing.
Good luck.
Good luck.
2021 C2 of the Year Finalist - Unmodified
2017 C3 of Year Finalist
St. Jude Donor '13
Charles, these spring type benders work fine on thin wall tubing. Scott
http://www.sears.com/superior-tool-4...000P?rrec=true
