Frame Paint Help Please
Old 05-26-2016, 09:27 PM
Jeht
Jeht's Avatar
Default Frame Paint Help Please
Started blocking the first coat of slick sand on the frame, will put one more coat and wet sand. What would you apply to the frame BC/CC or single stage spray can?
Old 05-26-2016, 09:50 PM
ChattanoogaJSB
Support Corvetteforum!
ChattanoogaJSB's Avatar
Many opinions on this but if it were mine I would spray it well with epoxy primer- like SPI. It will be be durable and attractive for years to come and not have a greasy sheen. It is rock hard, airtight, and resists contaminants well.
Just if it were mine.
Old 05-26-2016, 09:53 PM
desertpilgrim
desertpilgrim's Avatar
I guess it depends on how over-restored you want it to be.
Old 05-26-2016, 10:00 PM
ILBMF
ILBMF's Avatar
Looks to me like you have it figured out already. I also prefer epoxy primer
Old 05-26-2016, 10:16 PM
1snake
1snake's Avatar
SPI has the best products on the market, I know, I've used most of the others. Here's a pic. of my 65 restoration using their products on the frame.
Old 05-26-2016, 10:17 PM
Jeht
Jeht's Avatar
What are you insinuating by over restored? I could have painted my car and not touched the frame, new suit with muddy shoes!
Benton, here is a shot of the frame after I had it sandblasted. I sprayed black epoxy PPG, thought it looked good but didnt know how durable it would be.
Old 05-26-2016, 10:33 PM
ChattanoogaJSB
Sorry Jeht- it has epoxy already then slick sand to make it a little smoother and now you want to topcoat? I think I would once more do epoxy. Still my preference.
I used DP90 from ppg many years ago. They have improved it I believe and it was good back then. Nothing bad to say about it. I do like the SPI.
Jeht (05-27-2016)
Old 05-27-2016, 08:29 AM
Roger Walling
Roger Walling's Avatar
Received 1,589 Likes on 661 Posts
I used epoxy primer and DuPont Industrial Imron.
Very slick and chip resistant. Easy to keep clean.
Not NCRS correct but who gives a ----.
Jeht (05-27-2016)
Old 05-27-2016, 05:03 PM
Jeht
Jeht's Avatar
Thank you. Is this product what you have on the frame in the pic? It looks like a semi rather than a flat color of the PPG epoxy. The color on your frame is what I'm looking for.
Old 05-27-2016, 05:08 PM
64Corvette
64Corvette's Avatar
SPI.
I also used DP90 years ago and it has held up great!
Old 05-27-2016, 05:28 PM
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
FOR WHAT THIS IS WORTH:
Applying an epoxy primer before the 'slicksand' was a good move. NO DOUBT there!
Be careful of the thickness of your slicksand. Keep in mind you can stack layers and get the metal really slick and smooth...BUT...the downside effect of doing that is that it can chip REALLY EASY...and when you have body ground straps that need to be attached...you need to grind the stuff off to bare steel so you are actually getting a good ground....and then apply a die-electric grease to that area so the steel does not rust.
On top of the slicksand I would apply another coat of the epoxy if I did it that way.
The old school PPG epoxy.... where it is still mixed 1:1 is out there and in a commercial line....or you can use the SPI stuff ( I never had...but it seems to be good stuff) or the DP90LF.....or spray paint it with whatever you choose.
I PERSONALLY do not think PPG IMPROVED on the DP90...I think what they did was design it to comply with EPA stuff and make it so people in the industry would use it. What I used back when the stuff hit the market is NOT what they sell in the mainstream of products today. Going from a 1:1 mix to a 2:1 mix...and then the 402 hardener that came out for immediate mix and shoot.... instead of the 401 which made a person have to wait 30 minutes for the chemicals to induct with each other. I just like the old stuff myself....and I am not saying that the new stuff is crap...because it is not.
DUB
Old 05-27-2016, 06:35 PM
Lotsacubes
Lotsacubes's Avatar
Is anything ever done to treat the inside of the rails? Seems like something called POR has been discussed.
Old 05-27-2016, 06:51 PM
ChattanoogaJSB
Eastwood- not my first choice - makes a lot to spray into the rails. I'll bet other sources do too. Maybe someone will chime in. I don't know if the POR 15 guys do or not- but their product is so gross I would probably seek another source.
I agree it would be a shame not to treat the inside!
Old 05-27-2016, 07:08 PM
DUB
DUB's Avatar
Yes...POR-15 can be used but if you do not use their MARINE CLEAN and ACID ETCH...you are wasting your time and money. It will not stick due to NOT being ready for it to stick to the metal.
A messy job ( YES..I AGREE) and if the inside of the frame is a major concern of my customer....I would then now be able to suggest sending the frame off and have it dipped.
DUB
Old 05-28-2016, 05:05 PM
TJefferson2020
TJefferson2020's Avatar
Had my frame acid dipped - then sprayed rust inhibitor (don't remember the brand) inside with a long spray attachment. Then shot it with DP90.
11 years later, it still looks good - very durable. In fact I went to strip some of the bumper mounts that were originally finished as above and that DP90 just doesn't come off. Amazing adhesion and durability.
Finish is satin.
Old 06-05-2016, 03:18 PM
Jeht
Jeht's Avatar
Decided on the SPI Epoxy primer, followed recommendation and applied 3 coats.
Old 06-05-2016, 03:45 PM
GTOguy
GTOguy's Avatar
Received 3,443 Likes on 2,113 Posts
In the industry, rust inhibitor wax is sprayed inside frame rails with a long tube to protect against corrosion. This started in the 1990's. As for me, the very thought of block sanding a frame is absurd. But then, I'm in California and am used to rust free old cars. For me, a spray bomb of semi-gloss chassis paint is fine. Looks appropriate and holds up. Over restored cars do nothing for me.
To Frame Paint Help Please
Old 06-05-2016, 04:23 PM
Jeht
Jeht's Avatar
The ONLY way to protect the inside of the frame is stated by DUB in earlier post. The magic wand is not not to protect if you are planning on doing it correct, it needs to be dipped.
What you may find absurd is your personal opinion, you and BUBBA can spray bomb all you want!
Only reason the frame was sanded is to clean up imperfections from a 50 year old car which had been driven over the course of it's life. I'm not on here to get in a pissing/shouting contest war of words, I look for help and advise from fellow enthusiast.
Old 06-05-2016, 05:31 PM
Railroadman
Railroadman's Avatar
Received 5,008 Likes on 2,528 Posts
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Originally Posted by Jeht
What you may find absurd is your personal opinion, you and BUBBA can spray bomb all you want! I'm not on here to get in a pissing/shouting contest war of words, I look for help and advise from fellow enthusiast.
Geez, take a ! GTOguy clearly stated he was expressing his own opinion, which is just as valid as anyone else's when opinions have been requested. Nobody is talking about a pissing contest except you, I don't understand your hostility.
Old 06-05-2016, 05:35 PM
ricks327
ricks327's Avatar
Received 1,613 Likes on 901 Posts
Looks great to me!
Jeht (06-05-2016)
Quick Reply: Frame Paint Help Please
