[C2] Lucky break today
Lucky break today
Last 3 or 4 months noticing an increasing oil drip around the engine/transmission seam on my '64, and when I took a quick look underneath last week, figured rear main seal was leaking. Put it up on jackstands today and did a closer inspection, including removing inspection cover. Turns out oil filter canister seal was the culprit, so a quick oil and filter change with new seal cured the leak. Wiped it all down and drove around for 1/2hr, then placed a piece of cardboard underneath, and after a few hours, it's leak free.
Enjoy while you can.
Received 2,688 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Life is good Enjoy em while you can.
Larry
I wouldn't mind it marking it's spot a little, but it kept growing and growing!
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
-- Steve
If my 66 stops leaking it means its out of oil.
I have been saying for 25 years or so Im gonna fix it ☺
Maybe this coming winter.
Good news for a change
Once in a while, not to often, a guy gets a break. Suggest you write down a time and date of the break for further reference.
I put it up on the lift had the wife start it up and saw that the oil was coming from the filter area. He had a spin on. with the adapter.
I found 2 o rings. Took them out and replaced it with a new one and had no leaks. Lift pays dividends again.
