[C1] Replaced heater core...should I worry about the valve?
Just replaced the heater core in my '60 this past weekend and I have to say, it was one of the quickest projects I've ever done. I bought a replacement heater core 2 years ago and it's been sitting in a box until I got up the nerve and set aside the time to tackle this install.
After carefully removing the firewall stud nuts and the cables, I tried to chase down the brown wire to the blower assembly, but I lost it up under the dash and couldn't figure out where the end was. I ended up cutting the wire and resoldering it instead of spending another 30 mins under the hot dash laying on my back looking for the end of the wire. Plus, someone before me had taken the time to secure it in a cluster of dash wires with cable straps that I did not want to disturb since the cluster was kept clear from the wiper transmission cables path of destruction.
Once I got the heater assembly out, it was easy to disassemble the heater core, insert the replacement and button it back up. I inspected the heater valve and did not see any obvious signs of leakage, so I lubricated the valve lever and spring assembly and enlisted my neighbor to watch the firewall while I coaxed it into place.
One thing that took a little time was pulling the fresh air valve cable thru the small hole at the top of the plastic fresh air opening. I realized I needed to pull this cable thru the small hole only after I had gotten the four heater studs in place and nuts started. Instead of having to start all over again, I ran a pull wire from the firewall thru that hole back under the dash and secured it to the loop that attaches to the fresh air valve lever. Worked like a charm.
At this point, I began to think about the heater valve as a possible culprit to my soggy anti-freeze smelling passenger floor carpet so I did not hook up the heater hoses to the heater core.
My question is, has anyone ever experienced one of these valves leaking instead of the heater core itself? It would be a shame to hook up the heater hoses only to have a nice leak from the valve. If there is no way to separately test the heater valve, then I guess I have no choice, but to hook up the line, bleed the air from the heater core and hope for the best.
Any information would be great and I will post my results as well.
Ted
Ted
One month after I replaced my heater core, the valve started leaking. On my brand new carpet.
Since it is pain to hook up stuff under the dash, i always would recommend changing the valve with the core.
Doug
Doug
When I replaced my heater valve the repro does not come with the silver capillary tube like the original. You can fake it by sticking the old capillary tube into the valve and terminate the other end like the original was. (If your car is judged or whatever)...
The point being don't toss that capillary tube along with the old heater valve...
I also hope you used the correct copper elbow (Paragon has it) as shown near the end of this document. Some vendors sell one that is more like a plumbing fixture and can be the cause of leaks...
A good set of Corbin clamp pliers with swiveling heads makes the job scads easier as well!
glenn c6 (12-09-2020)
The valve most likely has the same age and deterioration as the heater core. REPLACE it.
Received 3,443 Likes
X3 or 4.....I replaced the valve in my '61, because with my luck, I KNEW it was going to fail. My heater core replacement was good quality, but a hair bigger than the oem, so it was a super tight fit in the case. Glad yours fit properly.
DZ
It is easier to change the valve now.
Also per Johnz recommendations have the new valve pressure tested before you install it.
I had my brand new core and valve pressure tested at my local radiator shop and sure enough the new valve was leaking. I brought it home, added some new solder to the joints and it has been great. Had I not tested it you can imagine the pain and frustration of having to remove it again.
