[C2] On a 63 SWC with the glass roll down how much is sticking up
I installed some window bumpers and now when the glass is rolled down all the way, the glass sticks up above the door about 1/2". Is this correct. Without the bumper the glass goes down past the top of door window opening.
1963swc
Looks like approx. 1/2 3/4 below stainless door trim.
Of course the window shouldn't stick up....do those stops even go on a coupe ? What do they look like ?
The vendor catalogs show a rubber bumper used on late 63's. Not sure if that is for coupes or open cars. I would also like to know if the coupe is suppose to have a bumper for the glass. Makes sense that some sort of stop would be required. Anyone know for sure and what it looks like.
Your AIM should show it - I'm not near mine..
On the end of the rear channel there is a 1/8" hole that the piece in the picture was press on. If you look at the picture you will see that it is broken on the end. Does anybody sell this part. I have an early car so not sure if it was changed later on. I need two. The AIM does not show this part. It only shows the open car stop.
I just looked at my windows on my 63 SWC and the glass is even with the door opening (surprisingly)
