[C2] 1963 Firewall Holes: What goes there?
They might be for rubber plugs that hold the firewall insulation in place. You can see one of the plugs in the bottom of your first pic. Look from the inside and see if there is a hole in the insulation that lines up with the hole in the firewall. Or, the hole could be for something else.
My original May 63 car has a fat plug in there (first pic you provided) as shown...
My May 15th or 18th 1963 (cant remember which) fire-wall last year.
Thanks Frankie and Morley. Looks like a rubber insulation plug as Ken suggested. I'm thinking the hole by the speedo cable must be the same thing as it's about the same size.
I appreciate your help, and the pics.
I've got the body off and on the dolly, so I'm finding more out then I want to at the moment:-) I've got a July built car, and the frame was badly rotted. She be back together mid August. I appreciate your help!
Nice project - I don't know how correct you're trying to be but that master cylinder with the flip up bail is a '64...
Good catch Frankie. My original is on the shelf; needs a sleeve. the '64 was the path of least financial resistance. I'm getting check writing fatigue.
