Carb Float Housing Problem
Just wondering if anybody has had the same problem as myself and what was the solution.
I do not have the original carb on my 66 327/300 but have a List No 3837 which is almost identical to the original but has non adjustable floats. The floats are held in position by a pin which goes into a blind hole in the side of the housing and seems originally to be an interference fit. This pin on the primary housing has come out twice in 2 years causing flooding of the carb. I need to fix the pin back in the housing so it does not come out again. Any suggestions to the best way to do this.
Thanks Phil
Thanks Phil
Thanks Phil
Thanks Phil
Gary
Thanks Phil
Thanks Phil
veeeight (07-27-2016)
