[C2] ID location on WCFB
ID location on WCFB
Picked up some 64 parts. Was supposed to be 300 hp parts, but the carb is a WCFB (250 hp) with iron throttle plate. Is this correct throttle plate? Not aluminum? Where is ID stamping?
If there are brass/aluminum triangular takes they might be correct, but those can be swapped; here ya go:
Thanks Frankie. It's a 1642 airhorn, but the ID tag is long gone. I see in the pic the throttle plates are iron! Puzzle is coming together. 2" exhaust pipes.
