Adding shoulder belts--frame anchor??
I am adding shoulder belts and headrests to my late '66 coupe (which already has the factory rear fender mounts for the shoulder belt) for safety in the event of collision. Would it be advisable to add some kind of frame anchor to the shoulder belt mounting plate? Did GM ever engineer such a part or is it not necessary if you already have frame anchor cables for the lap belts?
Thanks!!
Thanks!!
Received 2,127 Likes
Do a search. This has been discussed in the past, with no clear direction. Dennis
Belts
You may want to check over at the C-3 forum for a solution. The 68 and up came standard with shoulder belts. The frames are essentially the same. I would check my 68, but it is in storage. I can give a look at my 68 AIM. Jerry
Thanks--great idea! I will check C3 out as well. If you have a chance to look at your AIM please let me know! 👍
