[C1] Original '57 - what's a mystery?
#41
I mentioned in another post regarding the paint that it is similar to a freshly minted penny - the current issue that has a pink tint. I noticed this in places behind the door panels. I'll try to get a CYMK and hex match for display correction at some point.
The weatherstrip marks are as you say - image attached. They are spaced on the longer pieces such that only 2 are visible on the trunk left and right side center.
#42
Quote:...you will also see at the cut ends of all of the weatherstrips a small white (yellowed) spec of material...
May I ask one more favor. If you could take a few pics of the door mains at the top where there should be a little metal clip that goes over the cut end. This would be just below the window and to the side of the exterior door handle. There is always a bunch of confusion as to how this should look for judging. Thanks.
#44
Panama58
