'62 front wheel bearing adjustment
Old 08-25-2016, 12:43 PM
vetteless in Modesto
vetteless in Modesto's Avatar
Default '62 front wheel bearing adjustment
I was checking out my front brakes on my '62, and decided to inspect and repack my front wheel bearings and install new grease seals. The bearings are the ball bearing type. My question is regarding the adjustment of the bearings. ST-12 states:
2.) Tighten spindle nut to 33 ft. lbs. while rotating wheel
3.) Back off spindle nut until bearings are loose and retorque to 12 ft. lbs.
So...I performed step #2 with wheel spinning, BUT performed step #3 with the wheel NOT spinning (I actually retorqued to 144 inch lbs since my other torque wrench doesn't go down to 12 ft lbs).
My question: Should the wheel be spinning when performing step #3? Maybe I'm splitting hairs here?
Back in the old days on our cars with tapered roller bearings, we would just use a crescent wrench and go by feel while spinning the wheel the whole time, just until the bearing was slightly snug.
Thanks!
Old 08-25-2016, 12:49 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
can't specifically comment on the torque and method, but there are roller bearings available for the C1
Bill
Old 08-25-2016, 08:08 PM
Redbird
Support Corvetteforum!
Redbird's Avatar
2021 C2 of the Year Finalist - Unmodified
C2 of Year Finalist (stock) 2019
2016 C2 of Year Finalist
I have always gone by feel. Never had a failure.
Old 08-25-2016, 08:19 PM
Redbird
Redbird's Avatar
Old 08-25-2016, 08:27 PM
vettepoor
vettepoor's Avatar
Same here. I have ball bearings on my 57, always go by feel with zero issues.
Old 08-25-2016, 09:15 PM
1snake
1snake's Avatar
Feel means nothing. Ball bearings need to be pre-loaded. Doing the same to roller bearings will destroy them in short order. Follow the prescribed procedure for the bearing you are using.
Old 08-26-2016, 12:23 AM
Thanks to all who've replied, I appreciate your help. I guess my question is: when backing off on spindle nut and doing the re-torque to 12 ft lbs, should the wheel be spinning or not?
Old 08-26-2016, 08:15 AM
jim lockwood
jim lockwood's Avatar
Received 6,507 Likes on 2,996 Posts
C2 of Year Finalist (track prepared) 2019
I spin the wheel any time I'm applying measured torque to the nut.
When backing the nut off, leave the wheel stationary.
You don't want to unseat the bearings you just seated with the previous application of ~30 ft-lbs torque.
Jim
vetteless in Modesto (08-28-2016)
Old 08-26-2016, 10:49 AM
GTOguy
GTOguy's Avatar
Received 3,443 Likes on 2,113 Posts
Going by 'fee'l is perfectly viable, provided one is in possession of the right 'feel'. Many of us are, and have been using it for decades with excellent results. Tools and specifications are only as effective as those using them. My biggest tool is my brain. Your mileage may vary.
Old 08-28-2016, 01:46 AM
Jim
Thanks Jim! I'll go back and re-torque.
-Steve
Old 10-23-2016, 04:15 PM
jerry gollnick
jerry gollnick's Avatar
Jim
Does anyone provide TAPERED roller bearing for C1s?
Old 10-23-2016, 04:29 PM
DZAUTO
DZAUTO's Avatar
Received 3,766 Likes on 1,669 Posts
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
Yes, it's been covered here several times.
Here is the best source, Allied Bearing Sales in LA, CA. The aftermarket sources also sell them, but they are MUCH cheaper from Allied.
http://www.superpages.com/bp/los-ang...0018138791.htm
I've had them in the 56 and the 51 Chevy for about 30yrs with ZERO issues.
By the way, let's give credit where credit is due. Roy Braatz was the first to make this information available MANY, MANY years ago. I followed his advice.
They are NOT, repeat, NOT available from the automotive parts houses such as NAPA, O'Reilly, Autozone, etc, etc.
The following 2 users liked this post by DZAUTO:
jerry gollnick (10-24-2016), mcb55-210 (10-23-2016)
To '62 front wheel bearing adjustment
Quick Reply: '62 front wheel bearing adjustment
