Hot console cover over transmission hump
2017 C2 of Year Finalist
2016 C2 of Year Finalist
I purchased a 1966 coupe with 327/300 motor and powerglide transmission a month ago. AC works, but the entire metal console cover including the transmission shift mechanism get so hot that it is uncomfortable to touch after driving the vehicle for a while. Transmission seems to be okay, but I am wondering if this is normal. I know that corvettes have an engine compartment heating problem, but this is a new one with the transmission hump putting out this much heat. Is this normal? Thanks
Received 6,946 Likes
2015 C2 of Year Finalist
No it's not normal. Look on the underside above the trans and see if the factory insulation is in place
William Buckley (09-03-2016)
St. Jude Donor '07
there is a tremendous amount of engine compartment heat that passes under the floor and down the transmission tunnel. there are times that it is 'uncomfortable' to hold my hand on the shifter base or the floor. I have taken to propping the back of the hood up whenever in traffic or even on the road; lets that heat out faster/easier.
insulation is your friend... make sure you have at least all the factory insulation in place on the firewall and the transmission tunnel.
Bill
Bill
C2 of Year Finalist (appearance mods) 2019
I had the same problem when I first bought my car. What I did was pull the console and line it with the thin insulation that has foil on both sides (I got it at Home Depot). I couldn't wear shorts at first because the metal would burn my leg. Now I could put my cheek against it without hurting myself. It made a world of difference and I already had the insulation between the trans and the tunnel.
Thanks K.C. Excellent idea and easier to do than to try to get insulation between the transmission and the body. I will check mine the next time that it is on the rack, but will be visiting Home Depot.
just to note its normal for it all to be warm to the touch and after all it is metal and heat transfers easy. but its not normal to burn your self on it either.
If you have a C2, there is an insulation blanket attached to the bottom of the tunnel, above the tranny. There should be two exhaust pipe metal heat shields attached to each exhaust pipe in the same area. They are warm, though!
I used the same product that KC John did and it definitely does help. If, by chance, the stock transmission tunnel heat cover is missing NAPA sells a self adhesive backed thermal shield that you can use to help cover the underside of the tunnel until or unless you pull the transmission. Lastly, I used a thermal wrap (usually used on headers) that I ordered through Summit which also cut heat transfer dramatically since those two little tiny stock "heat shields" are, IMO pretty much useless.
Gary
The wrap actually goes all the way up to the manifolds but, harder to see 'cause I used a darker color to be less conspicuous. The stuff around the tunnel is from NAPA.
Home Depot foil insulation prior to new jute and carpet . Has an R factor and is produced for home ducting. Lightweight and very cheap!
Gary
William Buckley (09-05-2016)
