Distributor Shaft Dimple Not In Line
Old 09-03-2016, 03:34 AM
65 vette dude
65 vette dude's Avatar
Default Distributor Shaft Dimple Not In Line
Took my distributor out today, and noticed my dimple does not line up with the rotor tip. Its not 180º out either. With the rotor pointer at 12 o'clock.....the dimple is at 3 o'clock....or about 90º out. I thought they were suppose to be directly in line. What gives.....wrong distributor rotor?
Old 09-03-2016, 10:35 AM
tbarb
tbarb's Avatar
Without looking at distributor parts sounds like either the mainshaft or gear has been changed.
I doubt the rotor is at fault, find some pics and see if the drilled hole through the mainshaft is in position like other shafts as that may give you a indication what's been changed.
How does the vacuum control line up on the intake manifold between the coil bracket on one end and the intake runner on the other end. Ifit's somewhere in the middle or near the coil bracket I say it's good to go.
65 vette dude (09-03-2016)
Old 09-03-2016, 11:49 AM
plaidside
plaidside's Avatar
Received 1,124 Likes on 552 Posts
Here are some pictures that might help you figure out what is wrong.
These are from an article I did on distributor rebuild.
Joe
Relationship of the pin hole to oil pump shaft drive:
Dimple to pin hole:
Rotor tip to dimple:
Football to pin hole:
Old 09-03-2016, 02:15 PM
65tripleblack
65tripleblack's Avatar
If somebody replaced the original distributor gear with a new type, melonized gear, that is normal. The original gear and new gear have different dimple orientations.
Old 09-03-2016, 07:59 PM
JohnZ
Support Corvetteforum!
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Non-GM cams can also show that anomaly, as the indexing of the pin is not understood in the aftermarket, was never explained by GM, and only matters on the Corvette due to the requirement for advance can alignment with the vacuum advance opening in the upper ignition shielding.
65 vette dude (09-04-2016)
Old 09-04-2016, 08:42 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
I just love when JohnZ sheds the light of day on a topic with a single sentence
To Distributor Shaft Dimple Not In Line
Quick Reply: Distributor Shaft Dimple Not In Line
