[C1] Florida Garage Heat
#41
I remember driving down to Key West and coming upon a road-kill snake that very easily stretched across our lane of traffic.
Another time going home to Naples from Miami in the evening on Hwy 41 and literally having to take the shoulder to go around a stubborn gator that wasn't going to move out of the lane of traffic.. They don't call it Alligator Alley for nothing.
Yes, I'd still move back.
Mike
Mike
#42
Received 1,581 Likes
St. Jude Donor '20-'21-'22-'23-'24
Five coral snakes!? Wow! We've been here for 5 years. We've seen our share of snakes but nothing poisonous.
Steve
#43
Robert - Would Stormy stay away from a snake? I don't think my dog would. That could end up really bad.
Steve
Steve
#44
So to keep my cars in good shape and to give me enough to work on them with a closed door, a dehumidifier draining out of the door with a duct from my central A/c should work?
thanks
jax
ps: the gators do make some strange clicking noises during mating season. I hear them on the lake behind my house. I am very west near the Everglades.
thanks
jax
#45
thanks
jax
thanks
jax
Also, without a return air vent, I'm not sure how well an added vent would perform. We have 3 air returns in the main part of the house but none in the garage.
So, I changed my plans and put the mini-split system in the garage.
Steve
#46
My main blower unit is in the garage. The exhaust is on wall opposite garage wall in unit. Ducting in attic has a place where Lyndstrom said it is safe to run duct out.
jax
jax
#47
We have to keep her on a short tight leash as she likes to poke her nose into bushes and ground cover to capture the essence of all the Pee-Mail! I'm sure she'd be curious if she came face to face with a snake.
Robert
#48
Here's a picture of our dog, SinDee when we were up in Minnesota with her head down a gopher hole. There were lots of gopher holes at that campground and she was going from one to the next, shoving her head down to see what she could find without any hesitation whatsoever.
Steve
#49
Our air handler shares a common wall with the main house. Cooled air goes straight up into the attic and then over to the main house. No ductwork to cut into over the garage ceiling.
Steve
#50
thanks
jax
thanks
jax
My garage in Mt Dora, some tree shade during early and late time of the day, only gets over 90* after I pull a hot car into there, it has been high 80's other wise this summer. However, it has a storage room above most of it that I'm sure is 100* +. So, maybe look into added insulation or power vents.
Robert
#51
Received 1,099 Likes
The only gators here are Gator Fans (as in football).
#52
Might advise your MN friends to www.visitsouthwalton.com
Steve
#53
Alligators are prevalent all the way up to South Carolina..the limitation is more in the nature of the water as they are fresh water animals...
#54
Yes it can get cold to the tune of freezing. One year I saw icicles all around the end of the roof. But in 22 yrs, never any snow. For our northern friends we have stuff that looks like snow year around to wit:
#55
Now that you've read all that....my split window went the OTHER way...when I bought it out of Northern Ohio 3 years ago the paint was perfect (IIRC the car had a total repaint in 2009). After about 6 months in Orlando summer heat the car got the 'mumps' and a few bubbles cropped up on the passenger door and along the stinger on the hood. Very weird - you could see them get larger day-by-day (outgassing ?). Clearly not solvent pop so many years after the repaint.
Never did figure out if it was contamination in the fiberglass or bad primer or what. The paint simply didn't adhere to the primer substrate anymore.
Luckily I had original touch up paint that came with the car and access to excellent painter talent so it turned out well...and no more problems 2-1/2 years later.
Something to watch out for.
#56
A split system like Steve has is the ideal. You could also get and run a dehumidifier most of the time with the AC only for extremes or work in the garage by yourself/friends.
Larry
#58
think I will start with a dehumidifier with a hose running under my garage door to drop out.
jax
#59
This was completed in July. Thanks to John Z, and others for their advice when I asked. I have 3 Liftmaster "sidewinder" openers and high lift tracks on 12.5 ft. ceilings and 2 4-post 9,000 pound lifts. I have radiant heat over a multi-layer insulation package and epoxy on top of that. Stretch energy code in my town requires heavy insulation in walls and attic. I'm in New England. I find A/C unnecessary, but since humidity control is what's important & not temperature alone, I employ a portable console type A/C unit set to dehumidifier mode - does the trick nicely.
Da
Da
#60
Larry - Thanks. And, yes, I used to cringe whenever I opened the garage door and let all that cool air out but I found if I'm just going out (or in) and close the door quickly behind me, I don't lose very much cooling. I don't have a passage door in my garage to the outside. Wish I did, but I only have the garage door as an exit to the outdoors.
The garage has a 34-foot east-facing block wall with 3 windows. The AC struggled at first with the heat load so I added the 5/8" R-Max you see in the picture. It only has an R value of 4.0 but it makes a huge difference. I also put solar film on the windows. Of course, attic insulation and an insulated garage door are pretty much mandatory.
If you're wondering about the gallon jugs of dark liquid in the photo, that's teal Rit dye. I'm getting ready to dye my teal carpet back to it's original color. The carpet is in good condition but very faded. Anyway, with the A/C unit directly over the car blowing 72 degree air down at the interior, the carpet should dry very quickly.
Steve
Steve
Hi Steve... let me know how your dye job works out. My 67 has perfect original interior and black carpets, with the exception of faded black. I had thought about dying the carpets. I hate to pull out the originals just due to fading as they are otherwise perfect (original only once as they say). But a thread here on the forum indicated poor results trying to re-dye. Like to know how you make out.
Jim
