[C2] 396 MN questions
396 MN questions
Hi,
I have the opportunity to buy a 1965 C2 396 Big Block wich is matching numbers.
I hesitate a little because it's expensive due to the matching numbers.
It has been restored in canada in 2009-2010
Could you tell me if it seems a good deal ? Thank you.
It looks like a very nice car with some minor modifications. I think at this point it would largely depend on "The Deal"...
Good luck... GUSTO
Good luck... GUSTO
How Much...$$$$
Also, does it come with the original parts?
And why does it have 2 radiator caps...i thought big blocks didn't reservoir
Is the engine pad cracked?
There are MANY things that are incorrect on that car, The radiator is one. It also has a small block rear-end. The stamp pad is VERY questionable. It may be a nice car but not very original and WAY over-priced.
Spare tire tub/lid
Rear spring
Exhaust manifold
To name a few
There is a crack to the right on the pad...
:::EDIT:::
All the stock front steering parts....
Rear spring
Exhaust manifold
To name a few
:::EDIT:::
And what is a small block rear-end ?
For the crack, you're right, I will have to check it when I'll see the car again !
Picture of the Trim Tag is needed. Was the car initially delivered in Canada so that there would be shipping records? By the way, April 3, 1965 was a Saturday.
All big block C2 differentials used half shafts that attached to the yolks with caps and bolts, the small blocks used the U joints which are obvious in the photos you posted. It is easy to add rear sway bars to simulate a big block C2 but takes a little more work to change out differential parts.
Rear
Big blocks had capscrews (bolts) instead of U bolts like small block cars. The 65's BB cars did have expansion tanks. This car has alot of questionable stuff for that kind of money.
It also has a rack & pinion steering gear, wrong master cyl. valve covers and PVC system which indicates a different carb. than original.
Again, not an original car and overpriced.
How is the car advertised, "original-nice driver?" If you pay that price, you'll have a very difficult time finding someone in the future that will. Like they say, there's a butt for every seat.....
In April 2014, it was added to the C-2 registry by a car dealer in France - http://www.c2registry.org/index.php?...te&car_id=2817
Actually, it's the side yolks in the rear end that uses the different caps. It's definitely a small block rear end, not a big block. Big blocks had shot peened half shafts but they look the same as small block ones. It's also missing the rear sway bar, another indication that this may be a small block car.
I would need a lot more inspection and a lot more proof that this was truly a factory big block car. I would also like to see the Trim Tag, block casting number and casting date, transmission numbers and dates, rear end stamping and date.
A pretty car for sure..............but way to many deviations from original to be a "matching numbers" car.
My opinion.
Larry
