Need a Pic Please
Need a Pic Please
'66 power brake car. I just installed all new SS brake lines and I could use a pic of the lines where they come up from the frame to the master cylinder. In particular LI Corvette parts diagram shows the line that comes from the left side manifold block, around the side of the steering box and shows the line going to the left side of the Z-bar frame weldment. I want to make sure the lines don't interfere with the clutch linkage or spring which are not on the car yet.
The way the line came pre-bent it needs to go to the right side of the weldment which is where I have it now. Another question I have is where the line from the rear goes along the frame up front does a clamp go on the frame past the firewall where the frame makes a right angle turn or just the one slightly behind the firewall?
The clip kit came with what looks like galvanized larger clips which I know go on the front to rear frame rail, but the kit also has 2 smaller chrome plated clips which I assume is for the front frame crossmember on the crossover line. This car doesn't have any threaded holes in the frame there, just one center hole for the push in clip. I assume they are for a different mid year or what?
Lastly, the LI Corvette diagram shows some sort of clip suspended just below the master cylinder which seems to tie both lines together. That didn't come in the clip kit...not sure it's even necessary or for another mid year car.
I tried to take a photo of mine but you really can't see anything in a photo from up above. Not sure how to get you what you are looking for.
