Hood stuck closed on a 62
Hope someone out there has some first hand experience with opening the hood on a 62. I knew the hood was not perfectly aligned but I made a bone headed mistake and dropped the hood. It latched tight. I mean TIGHT. I can only move the release handle about 1/8", certainly not enough to release the latches.
I have tried to have 2 people push down on the rear L & R corners of the hood while I pulled on the handle. Nothing.
Any suggestions, pictures would be greatly appreciated.
Bob
Bob
2016 C1 of Year Finalist
Get under the car on one side, reach up and trip the latch.
Do the same on the other side. Not easy but possible.
Or you might be able to snake a wire coat hanger up to the latch.
You might have to remove the splash pans for access, I don't remember...
I agree, but the hanger wire may not be strong; i would rather try with a rod to pull the rectangle latches down in each side.
I agree, only method on the '59 I had was to jack it up and physically trip the latches from under the car, not fun but doable.
Ohiovet: Can you take a picture of your latch and in paeticular the '...rectangle latch...' you mentioned? I have a good mental picture of the male part on the hood. But I do not have a mental picture of the underside of the female portion of the latch on the firewall.
Hope this gives you some idea of what the latches look like and how they operate.
Dave Z
62 Hood latch pictures.
Here are a few pictures as follows:
Left side hood latch, closed.
Right side hood latch closed.
Right side hood latch OPEN.
As you can see the motion to open the hood is to pull (or push) the latch arm back.
Hope this helps.
Hope this helps.
OK, as a psychologist I want you to relax and to take some deep breaths with your eyes closed. Fine. Now understand that it has happened to many of us and it is a relatively easy thing to fix. You will need to get under the car and remove the splash pans, taking out the 7/16 bolts. Using a bright (LED) light look up and visualize the underside of what others have shown in their pictures. You will need a very long pry bar, a stout dowel or similar tool to work the lever back enough to release the male part of the latch. Some trial and error will be involved but the hood will indeed be released and you can then relax once again. I will send you a bill later. Good luck. Doc
Bob
Bob
When my 60 stuck closed I climbed under with a rubber hammer and pressed the handle against the back of the hood while a friend pulled up near a latch and we got it.
Another thing you might try is pushing the hood sideways while someone pulls the handle. Mine will stick every so often and just a nudge from the drivers side to the passengers side will release it.
I keep checking this thread every few hours to see if you got it and I'm sure I'm not the only one.
A couple years ago, after installing the hood on my '62, I had the same issue. I was able to snake my arm up alongside the firewall and released the latches on both sides without removing anything. I recall it being extremely uncomfortable, but I managed to get it done.
Mike
Mike
