To Prime Or Not To Prime That Is The Question????
Okay-exhaust manifolds are off my 66 to be painted with CF Archives suggested Seymour Cast Blast which should give me my desired original cast iron (not silvery) color. They are now in for media blasting. Google And CF Archives search have reveal some have used high temp primer and others say NO primer will hold up to heat. Also primer will give you a smoother paint finish which I really am not in favor of compared to the original cast unfinished ruffer look. Those of you that have successfully gained long term manifold painting results advise me to do????. I really, really don't want to screw this project up. THANK YOU for your consideration and advice
2023 C1 of the Year Finalist - Modified
2022 C1 of the Year Finalist - Modified
2020 C1 of the Year Finalist - Modified
2019 C1 of Year Finalist (performance mods)
2018 C1 of Year Finalist
No primer imo.
Most folks are very satisfied with the POR.
Larry
According to the Seymour website, their Cast Blast is rated at 250F. Now you may be referring to a High Temperature or Header Cast Blast or something similar, but your original post simply said Seymour Cast Blast.
You need to be more specific in your description or provide a Part Number.
The POR has a lot of happy followers.
You can select what you which.
Larry
As Larry sez , Cast Blast "Original" is good for 250F ... part # 16-048 aerosol.
Cast Blast also makes a "High Temp" version rated at 1,200F ... part # 16-2668 aerosol.
Regardless whether you use High Temp Cast Blast or POR 15 High Temp #4418, DO NOT prime first. I am not aware of any primer that is rated over 1,000F. Fyi, Bill
Bluffman (09-23-2016)
I used some low priced stuff from Ace hardware store. The key is to make sure that you send the wife to the beauty shop for a few hours, and bake the manifolds in the oven as detailed in the instructions (first at low temp, cool, then at high temp.)
Mine have lasted for a few years so far without any signs of failure.
Received 3,443 Likes
I've used stove paint and steam radiator paint for years. Cheap and lasts forever.
Gary
Maybe I'm lucky but, I've baked lots of parts over the years and I've never had it linger much more than a few hours.
Gary
