C2 ('67 BB) oil and filter question
I'm curious as to what the consensus is with regards to choice of oil and filter (spin on) for your BB rides. Do you use a zinc additive ?
Received 6,943 Likes
2015 C2 of Year Finalist
I use Brad Penn oil and a wix canister filter
I don't think a "consensus" is possible on the subject. But FWIW, I use the original canister with a Wix/ NAPA 1143 filter element and Amsoil AMO 10W40. I would not use any oil additives, select an oil that has adequate zinc and phosphorous content to provide antiwear for flat tappet cams and a suitable viscosity. There are many to choose from.
Mikado463 (09-30-2016)
Rotella T Triple Protection 10/40 with a wix canister filter.
So in another thread regarding Shell Rotella oil many rave about using Shell's Rotella diesel 15w 40. Sounds like another option I'll try in my 427 390hp.
Received 1,974 Likes
It's the only place where you will learn WHY CJ-4 is an optimum choice both technically and econmically and why BRAND NAME DOESN'T MATTER!
Duke
How many friggin' times do I have to attach the oil article. This is the second time, today, and I've attached it to at least a dozen other threads in the last several years including one I started specifically to post the article.
Duke
Duke
No test... just save the pdf and read it again when you have another engine oil question.
Duke
Duke
