Water Flow in a 1967 small block
I need to know which is correct. One thought is that you can put a shut off valve in the hose that leads to the heater core to keep hot water out of the heater core because the insulation is gone. Open the valve when you want heat inside the car.
The second thought is that by putting a shut off valve in that hose it will cause the car to overheat. The logic here, I believe, is because the expansion tank is tied in to the other hose that goes from the heater core to the water pump.
Which is right?
Thanks,
Bob
Which is right?
Thanks,
Bob
Received 1,534 Likes
If you think about it a minute, the main water flow is from the bottom of the radiator (suction) through the engine, and out through the thermostat to the top of the radiator.
The heater hoses from the pump and to the intake are just for the auxiliary heat (however, the heater core is a small radiator and may help cooling in a pinch). The heater core is not needed if the radiator is up to par. Hardly ever see a heater core in a race car.
The expansion tank must be left functional, not shut off, or you can over pressurize the radiator. Thus, if you valve one hose off, you will still have a path for expansion through the other hose to the engine. Thus, I don't think it matters which one or where you valve it off.
If you valve both hoses off, and the expansion tank is between the valves, you have isolated it from the system. Once again, NOT GOOD.
Bobty (10-11-2016)
Received 1,974 Likes
Placing a shutoff valve on the 5/8" heater inlet hose, which is the one from the inlet manifold nipple to the heater core inlet nipple is perfectly acceptable. This essentially reconfigures the system to how the C-48 heater delete option is functionally configured while leaving all the heater hoses intact. See your AIM.
The 5/8" shut off valve can be placed anywhere between the inlet manifold nipple and the heater inlet nipple
Duke
Duke
Did this a few years ago to reduce heat in passenger area and it works fine.
placed a valve about in the middle of the 5/8 hose about a year ago works great ,winter is coming ready to turn valve on to allow water to heater live in california so drive car year round and heater is good in winter
I like this idea. Thanks for tabling it Bobty.
I also like the look of those valves. Looked on line and didn't see one like it. Can You guys tell me where you got those valves? Thanks.
outofspec (10-13-2016)
Thanks to all that have posted.
