Day one 61 restoration
#41
Now the big question. How are you going to title the car? It looks like you are not putting the original motor back in the car plus that is not the original frame, so all you have is an original body and that is only if you do not resto-mod the body in some fashion.
#42
Man your project is looking great. With work and my son's house project I haven't touched mine since just before Christmas - but I plan to get back on it in late April. Have you gotten the rocker steel replaced?
#43
I just removed the upper braces in the dash that the hinge pillar supports attach to. I'm going to have them powder coated. I'm debating having all of the new steel powder coated as well, hinge supports, rockers supports and the other pieces. As soon as I'm done blasting the body I will start back with all of that assembly. I haven't been on it much during Jan and Feb due to honey due projects. I had some question about what I was gonna do to the bottom but after looking at Slalomfiend's that is gone.
#44
Finally got started on the blasting. Thanks to al I badgered about how they did this. I've got fiberglass all over me. I never expected to get covered from blasting. There is some erosion of the resin whether from time or from the blasting. Should I fill this before I spray it with epoxy primer or after. Would VPA be the thing to use here. On the fender I have the pieces that are missing and we have decided it would be better to repair rather than replace this panel. I have very little experience with fiberglass but that will change by the time I finish this little project. I'm open to all input. I will be replacing the quarters with wide panels.
#45
Not sure what fender repairs you are considering but if its anywhere on the front fenders then consider the '58-only metal reinforcement bars that run underneath the windsplits the length of the fender.
They'll strengthen things nicely, are invisible and the repros are about $100 and widely available - they fit all '58='62 cars....
#46
They're on the way. Once again thanks to you and the forum. I would have known nothing about them. I already have new steel for the rocker panel supports and hinge pillars. I took a bunch of stuff to the powder coater two weeks ago but I said I'm not going to get this new stuff coated. When the parts I got done were finished I decided I had to take them as well so I ordered the fender supports and will throw them in when they get here. The fender repair I was talking about is that gaping slice up in the first pic. Looks like it fell off of a jack of something.
#47
I see it, PS, just ahead of the lower cove area. I've seen similar gouges more than once...
#48
Received 1,428 Likes
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
#49
I hope what's left is good glass. The erosion I see from the blasting looks like it could have caused problems if I had just sanded or stripped it.
csherman (04-11-2017)
#52
Thanks guys. Dale you can't imagine how many hours I spent looking at that frame picture trying to pick up every detail and exactly why he does it. Everybody I know says you did not pay that much for this ragged *#€ car. ive done a little glass work but nothing on this scale. One of my car buddies asked "are you gonna be able to fix that fender". My glass plans are wide quarters, r&r the lower nose, repair numerous cracks that I will be posting pics of, slick the firewall with heater and wiper motor delete, and some type of hood latch change.
#53
#56
2023 Corvette of the Year Finalist - Modified
2022 C1 of the Year Winner - Modified
C1 of Year Finalist (performance mods) 2019
So Where is the project now?
Hi... have been through all this too. Many pictures and a couple of watch out fors... let us know where you are now.
Good luck
Good luck
Robert61 (11-13-2017)
#57
Well I'm working away, doesn't look like a bunch of progress yet. Guys like CorvetteSander seem to start on stuff and it's finished 3 days later. I had all of the steel work, i.e. hinge pillars, rocker supports, and the front supports powder coated and have replaced them. I smoothed the firewall, replaced the quarters with GTS quarters for more rubber, and I'm repairing various resin cracks. It actually took me at least three days to get the gas door fitted and contoured. Sermershime just called last week and they are shipping my hood surround and fender. So I'll be on that for a bit. There's no way for me to thank everyone enough for all of the tips and input I've received from fellow members. And I'm always open to any further comments about what I might be doing right or wrong, especially wrong!
#58
csherman (03-03-2020)
#60
I am going to make the adapter for the rotisserie first and use it to line everything up. Project creep kinda took over on the body. At first I was gona repair the front end and I am I'm just replacing everything that's bad. Then I wanted bigger tires and you saw the outcome of that. I was able to buy a nos lower nose piece that I was going to attach to the existing nose and then I said no I can't use that it's junk. Then while all of the front is off we decided it was the best time to mount the Vintage Air so I had to get that coming as well. My new parts are supposedly underway so we'll see how well all of it meshes together soon. My buddy that owns the shop you came to just ordered a frame kit for his wife's Model A. I hope to get my body finished with all of the major glass work and let it sit and cure while we do the Model A. Very busy winter ahead!
