Rick327 did you do all the dash lights or only the where the OE 1816 are located. Assume you did not do the brake or headlight flashing indicator lights. Did you do the signal lights? How about the high beam indicator light?
Just the 1816's, not the high beam, turn signal nor the brake/headlight warning lights. I did do the radio though. I also have LED taillight and front parking lenses.
Thanks for the info. Obviously I am thinking of doing the same.
When you added tailight/brake, BU lights and parking lights did you need to add the resister.
And here is an interesting one I just found, it comes with a remote control so your install could be completely hidden. I ordered one to try, I will let you know if it works as described.
