QUESTIONS for those who have original '63 seat belts, or who have taken them apart
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
For those of you who can look at their cars with original '63 seat belt IC-5000 buckles (actually, maybe a year or 2 earlier as well):
I recently installed an original set in my '63 after finding a set in dark blue. I removed the buckles and bought a fully restored set I bought at Bloomington. Yesterday before a drive, I went to fasten the driver's side and the buckle assembly fell apart in my hand.
It seems I have not lost any parts, except for the fastening tiny, tiny snap ring that holds it together on the end (see bottom picture). Theres a spring and a washer and a shaft and 4 small spacers that make it all work.
The snap ring either broke or vanished into thin air.
Can anyone with an original functional seat belt buckle look at the head of the shaft on the outside edge (first picture) and see if that little "notch" is in the same place on both buckles? Are they both at the 6 oclock position? In reassembling these, Im not sure if turning the shaft makes the spring under more tension... as is its not very tight or springy.
In the first picture, the buckle on the right has the shaft notch in the 6 oclock postion when holding the buckle with the shaft at the top. Thats the one thats intact and functional. The other on the left is loose.
Or, anyone who has disassembled this might know? If it's not the shaft orientation, what else makes the spring tighter?
Also, anyone know where I can get 1 (or a few) tiny snap rings like this? Of course I sold 2 sets of spare buckles in recent weeks. It seems its a 1/4" shaft size, but Im not positive. Havent been able to find one.
(Bottom picture, one on top has original still in place; bottom one is missing)
TIA
TIA
Here ya go...
Also I think the snap ring that you show is incorrect (too large), or may have been over-expanded, which may be why you lost the other one....here is one of mine...
Perhaps McMasters, Fastenall or Snake Oyl might have the small, correct snap rings...could be worth a call to Snake Oyl or one of the other classic belt restorers.
They may take pity on you and mail you one out (sorry, you're aren't getting mine)!
PS For what its worth neither of my buckles are 'snappy' in operation...the spring pressure to open them is minimal and, although they close on their own when buckled, its not by much....
vettebuyer6369 (10-17-2016)
Super helpful Frankie.
I think that answers the question regarding the orientation and the spring tension. The intact one is pretty tight.
Your point on the snap ring is interesting... seeing how these buckles are restored, I wonder if the reassembly involved them not being reinstalled correctly?
Its also interesting the "heads" of both ends of your shafts have a "flat dome" while mine are a little rounded.
Thanks again.
Thanks again.
Well mine are absolutely IC-5000 buckles (with patent numbers) along with the Irving Air Chute labels in tact. Now its a May 29th car if that could be a factor...
Our cars are barely a week apart, but I bought these belts in Lakeland this year and the restored buckles in Bloomington so they could be any date.
They are installed at 6:00 and 7:30 positions.
I believe they have NEVER been taken apart.
My snap rings fit like Frank's picture.
The following 2 users liked this post by Rich Yanulis:
vettebuyer6369 (10-17-2016),
Zoomin (10-17-2016)
Mine look like replacements don't know much on seal belts could be another vender.
I think little hardware like the shafts could easily change in small design over the course of the year... seen that before.
vettebuyer6369 (10-18-2016)
For what it's worth, I have quite a few original IC-5000 buckles and I've never seen any pin head or clip end like Frankie's. They always look like yours - either chrome or dull plated. But I have encountered some pins that were slightly shorter than others and they did not stick out far enough to put on the clip.
There were different IC-5000s over time. Some had small letters and some had large letters and the parts are unique to each.
Also, all you have to do to add more tension on the handle is rotate the hex of the pin and wind up the spring a little more.
Verne
Verne
That style clip is different though, from the snap ring design (with the holes) like my pic and ftf's pic. I'm not exactly sure if that would work. Let me research that further.
I did contact Sssnake Oyl and asked if they would sell me a couple of the correct snap rings, but they came back and told me to send them the belt and they would repair it. I guess I can't blame them.
Rt that is super nice and thoughtful of you.
Verne
Verne
Vettebuyer,
Here is a set of late 63 Daytona blue belts I restored for a certain very low digit NCRS member from Cumberland Maryland. You can see the correct orientation of the tension spring on one of the buckels. Every original set I've ever taken apart was clocked in this position. The flipper has a snappy response as well when released from the full up position.
PM your mailing address and I will mail you an correct snap ring.
Tracy
Tracy
Vettebuyer,
Tracy
Tracy
My pictures are blurry but I believe you can tell which way the slot is pointing. Also the snap ring picture is blurry and ring is very tiny. Pictures are of the drivers side but both belts are the same.The belts are original to the Jan car but I have a receipt where the previous owner had snake restore them.
