[C1] 1959 exhaust tunnels
Old 10-19-2016, 08:11 PM
chopperbob1
chopperbob1's Avatar
Default 1959 exhaust tunnels
how are 1959 exhaust tunnels installed?
Old 10-20-2016, 07:52 AM
csherman
csherman's Avatar
Received 1,421 Likes on 734 Posts
C1 of Year Finalist (stock) 2019
2018 C1 of Year Finalist
Originally or how to you replace them ?
Old 10-20-2016, 08:42 AM
rfn026
rfn026's Avatar
I need help with this one. I assume this is what we're talking about.
Richard Newton
Old 10-20-2016, 09:54 AM
wmf62
wmf62's Avatar
St. Jude Donor '07
Richard Newton
I've never seen such a thing.... hmmmmm
Bill
Old 10-20-2016, 10:17 AM
Pilot Dan
Pilot Dan's Avatar
These are installed from inside the trunk area on each side. Not a lot of room to work in there. They have some factory bonding material at each end and also use some sheet metal screws additionally in the brackets. Obviously, this would have to be done with the tailpipes removed as well. Pay attention to the angles as the pipes will have to be able to fit back through without touching to avoid rattles. Pilot Dan
Old 10-20-2016, 11:49 AM
cbernhardt
cbernhardt's Avatar
C1 of Year Finalist (track prepared) 2019
The original tubes are fiberglass, 2 pieces glued together.
Below is a picture of one of the tubes from my '59 and page from the AIM.
Charles
Old 10-20-2016, 12:54 PM
thoyer
Support Corvetteforum!
thoyer's Avatar
Charles
58's used the two piece fiberglass design. I believe the change over to the metal tube happened in early 59 so it is possible some early 59's had the two piece fiberglass setup.
You'll notice in the AIM image posted it shows the metal tube which was held in place with screws and some sealer. The 58 tubes were bonded in place, no screws.
Tom
Old 10-20-2016, 01:21 PM
Pilot Dan
Pilot Dan's Avatar
Tom
I checked my 59 AIM and it only depicts the metal ones for 59. I believe the changeover occurred in late 58 though.
Old 10-20-2016, 05:40 PM
mashinter
mashinter's Avatar
My 59 (assembled in December '58) has the fiberglass tunnels.
Old 10-20-2016, 10:51 PM
chopperbob1
thank for all the help my car does not have any so I have to put them in also what type of sealant do I use and what do I screw into?
Old 10-21-2016, 08:02 AM
Steve59
Steve59's Avatar
My March 59 has the fiberglass tubes
Old 10-21-2016, 11:46 AM
wilbur
wilbur's Avatar
Did 56 and 57 use the exact same fiberglass exhaust tunnels as 58 and early 59?
Old 10-21-2016, 12:12 PM
Pilot Dan
Pilot Dan's Avatar
That is consistent with the late 58 changeover.
The General used all the parts they had back in the day. They may have had some fiberglass pieces left over and so they were used. I can tell you from my own 59 an August car (very late) it has the early style hood latches for instance that were long changed over according to the AIM revision date, some cars before mine reported the 2nd design This stuff by no means is an exact science for sure
Old 10-21-2016, 12:17 PM
Loren Smith
Loren Smith's Avatar
My April 59 car has fiberglass tunnels. There is always the potential that the General used existing stock and new stock interchangeably during the transition.
Old 10-21-2016, 12:19 PM
Pilot Dan
Pilot Dan's Avatar
What's on there is a hardening adhesive like what was used on the body panels. Sealing it is not the issue, it must be well attached at each end. There are several good adhesive products available that will work. The screws are just self tapping philips head and go into the fiberglass. If you look at the new part, you will get an idea of where to look on the car. With a small mirror and light you should find the old screws or the holes depending on what's left. Pilot Dan
Do you know when your car was produced in 59?? I see the fiberglass tunnels are also available so the first thing I would do is to determine what was specifically in YOUR CAR originally if possible before ordering any parts.
Old 10-21-2016, 03:04 PM
csherman
csherman's Avatar
The 59 I have here - built in April has 'glass tunnels.
Old 10-21-2016, 08:18 PM
thoyer
thoyer's Avatar
Looks like the consensus we have going is the change over happened more towards the middle of the 59 model year. The OP can check for screw holes which may help indicate the type that was originally in the car.
Tom
To 1959 exhaust tunnels
Old 10-22-2016, 08:03 AM
rfn026
rfn026's Avatar
Does anyone make the fiberglass units today? My car was born on August 7, 1958.
Richard Newton
My Interior Project
Old 10-22-2016, 11:32 AM
Pilot Dan
Pilot Dan's Avatar
Richard Newton
My Interior Project
I found these at CC, presumably would also work on the 59's as well.
http://www.parts123.com/corvettecent...50e&ukey=43007
rfn026 (10-23-2016)
Old 10-23-2016, 07:08 AM
rfn026
rfn026's Avatar
I knew there was a reason I hav always like Corvette Central.
Has anyone installed the fiberglass version?
I don't see any mounting tabs.
Richard Newton
Quick Reply: [C1] 1959 exhaust tunnels
