[C2] I'm an idiot, vented gas cap not working
This was not my tank, it came out of my old boss's coupe about 4 years ago...yes it was running real bad on our way to a car show in the mountains, to "lake almanor", when we stopped to fuel up before we headed back after a car show...he said his fuel tank was gone...limped home and went out the next day to remove....he bought a correct vented cap...
God no!!!
Gary
So conceivably it would take greater than 14.7 psi to blow the tank back out...
Buuuut its early and I'm only one cup of coffee into my morning...
See vent to left side
Jack
The following 2 users liked this post by 65tripleblack:
Bob's 64 (10-25-2016),
Frankie the Fink (10-25-2016)
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Atmospheric sea level pressure is 14.7 psi on the tanks exterior, so as gas is gradually drawn from the tank and a vacuum is created, at some point, somethings gotta give...it just takes a while with the pissant fuel pump sucking away at low psi...
Gauge pressure is what your tire gauge, air compressor gauge, and most everything else you have reads.
Received 3,443 Likes
14.7 psi gauge pressure won't hurt a thing. I've pressure tested radiators over 20 psi....and the rubber tires in my '15 Ford run 70psi...No problem whatsoever blowing the tank back into shape with a 100 psi shop line.
2018 C1 of Year Finalist
I just cannot resist.
Its the same concept as taking a plastic gas can and pouring gas out without cracking the vent. Then traveling up into the mountains.
You can rig up an air compressor to the gas tank. Make sure its sealed up well so the pressure does not bleed off. Then take a small amount of air at a time to blow it back into shape. Just start off with a little pressure until it pops.
So now, the order was:
suck, blow, pop. What a stress reliever
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
Well look on the bright side.. it probably fits better now!
This happened to me IN AN AIRPLANE many years ago. My dad was a private pilot - we were in his Grumman Tiger.. Engine starts sputtering.. I look out my window, and the WING is puckered in!!!! Not good!
He switched over to the other tank and we landed ASAP... but wowza! That will get your heart going.
#33
62 fuel smell
thanks for this forum and topic.
i also have a fuel smell typical of this vintage (mine a 62).
i pulled the inspection cover off by the tank and all connections looked good and dry. I did note that the hose from the fuel fill to the tank was not a very good fit (a bit loose) and the gas cap side clamp is a challenge to tighten.
i gave them a twist and also sourced a non venting cap as suggested. I will road test and report back.
road test completed- no gas smell!!
fixes applied: new stant non vented (and good fitting) gas cap
adjusted clamps
replaced access cover screws
currently at 2700 ft elevation, curvy mountain roads and 1/3 tank.
adjusted clamps
#34
atmospheric pressure is 14.7 pounds per square inch and that is what pushed in the tank so you will need that plus more to push it back out
#35
tanks
So last winter I had the gas tank replaced in my '64 because of excessive rust. Had the original to me "vented" gas cap put back on the tank. However, I did notice at times, when opening the gas cap it wasn't venting properly and I could hear a WOOSH sound when taking the cap off. Well apparently it wasn't venting enough that the fuel pump was crushing/caving in the gas tank. Now the filler hole is 4 inches lower and I have to get a new gas tank.
Caution note to the others that may not realize, if you hear the woosh, check to make sure your gas cap is venting, or replace it before it causes bigger damage.
