Problems with newly rebuilt Muncie - Page 3 - CorvetteForum - Chevrolet Corvette Forum Discussion
C1 & C2 Corvettes
General C1 Corvette & C2 Corvette Discussion, Technical Info, Performance Upgrades, Project Builds, Restorations
Old 02-16-2017, 07:05 PM   #41
DUB
CF Senior Member
I can grasp the concept of the pedal moving to one side due to begin defective BUT...it would do it all the time when pressed if it is messed up. It is not going to 'self correct' itself.
IF the pedal were bad...I can not see how it would act differently and NOT allow the clutch to work when the engine is running and not running. Either the clutch releases or not...there is no in between.
You have your car in gear....have someone push on it and when you begin to press on your clutch pedal....when the car begins to roll...your clutch released. Simple as that.
I have mentioned it and will write it again. Many people do not check the bore concentricity. I have had GM bellhousiing be off as much as .020". I know Centerforce provides paperwork that they want people to check and correct this potential problem.
Also...I ASSUME NOTHING....when I get a new NON MAGNETIC oilite bushing..I check to make sure they go on the input shaft and not bind. And when I install it I am using a tool for installing it an not just beating it in where I can possibly put an impression in it and mess up the center hole. I am NOT saying that some of you messed up here when installing the pilot bushing...BUT...I have seen them where they are beat to crap....and when I pull the transmission and clutch off I can clearly see WHY the problem is occurring. A pilot bushing that was damaged during installation and witness marks on the face of the pilot bushing due to the person ramming the transmission in and missing the hole of the pilot bushing and leaving witness marks in the process.
DUB
DUB is online now   Reply With Quote
The Following User Says Thank You to DUB For This Useful Post:
GTOguy (02-16-2017)
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • Problems with newly rebuilt Muncie
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Manual transmissions won't go into forward gear Tewski C3 Tech/Performance 2 12-23-2016 02:17 PM
    '71 Muncie and Hurst Issue Kubs C3 Tech/Performance 4 07-30-2016 07:15 PM
    Muncie M20 sticking in 2nd gear solutions 63 340HP C1 & C2 Corvettes 41 06-23-2016 02:49 PM
    '61 4 speed shifter levers - correct position? johngammel C1 & C2 Corvettes 4 04-26-2016 02:42 PM
    Muncie Problems Trent McInturff C3 Tech/Performance 11 02-08-2016 09:19 PM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
