[C2] Help confirming engine id
All - Need some help confirming the pedigree of a 327 block I may buy. Owner states it is a 1964 Corvette block. Here are the numbers:
Casting #: 3782870
Date Code: B224
Journal Crank: 7178
Engine Suffix Code: F0228S
Everything seem to correlate to a Feb 22, 1964, 327 Corvette Block, Pistons, crank, 2 bolt. What is throwing me is the "S" at the end of the engine suffix code. It does not correlate to any of the 64 corvette engine configurations. Any idea? Could this just be a replacement engine manufactured in 1964? Also from the pic there is not a partial VIN in front of the engine suffix code.
Thanks in advance for the help - Tim
Casting #: 3782870
Date Code: B224
Journal Crank: 7178
Casting #: 3782870
Date Code: B224
Journal Crank: 7178
Casting #: 3782870
Date Code: B224
Journal Crank: 7178
:::EDIT:::
"The engine suffix code is a two or three digit identifier used during assembly to indicate an engines usage and horsepower rating"
Casting #: 3782870
Date Code: B224
Journal Crank: 7178
Casting #: 3782870
Date Code: B224
Journal Crank: 7178
PRTSkipper (11-16-2016)
I found this after my other post...
It it was "S" 1962 327 Powerglide full size
:::EDIT:::
If it was "SS" 1964 327 Pwrglide, hi perf. 300 4bbl Chevelle
It it was "SR" 1964 327 Powerglide 250 Chevelle/3200
Thanks for the feedback. It is just the one "S" in the suffix... no second letter, which as you found aligns to a 1962 327 but the casting dates code indicates a 1964. The mystery continues... although I think it is clear that what ever car this block came out of it was not a 1964 Corvette.
Received 1,283 Likes
Date Code: B224
translates as follows:
Block was cast on February 22, 1964 (B224)
F = Flint engine
0228 = assembly date of February 28th
S = 327, 250hp, 4bbl, powerglide, installed in a passenger car (Impala, etc.) This code was used from 1962-1964 for this engine application.
This was before VIN derivatives were used on lower horsepower engines in non-Corvette applications. By 1968, all engines had VIN derivatives, regardless of horsepower or application.
F = Flint engine
