Alternator and power steering on a ZZ502
Old 11-20-2016, 08:51 AM
1965fuelie
1965fuelie's Avatar
2018 C2 of Year Finalist
Default Alternator and power steering on a ZZ502
I am putting a ZZ502 into my '67. Will this kit fit and bolt on to my new engine?
http://www.zip-corvette.com/63-67-c2...mount-kit.html
Old 11-21-2016, 01:01 PM
Avispa
Avispa's Avatar
The kit will fit. You just need a few things that don't seem to be included. First is a short water pump. You will also need correct pulleys for the crank, water pump, PS pump and alternator. The kit comes with a 5/16 x 3/8 stud that fits in the front most drivers side exhaust manifold bolt hole. If you're running headers instead of a factory exhaust manifold you'll need to replace that stud with some 3/8" UNC threaded rod or 1 1/4 inch long stud and space out the PS pump bracket mounting "ear" with flat washers.
1965fuelie (11-21-2016)
Quick Reply: Alternator and power steering on a ZZ502
