BB Oil Drain Plug Question
Does the oil drain plug have or need a washer on it to seal the oil pan? If it does, what type of washer is used? Mine is a aftermarket magnetic drain plug. Thanks All.
All '67 drain plugs left the factory with a thin white nylon gasket under the head. It's spelled out in the judging guide.
babbah (12-05-2016)
Received 6,943 Likes
2015 C2 of Year Finalist
a nylon washer will work but not sure if they left the engine factory with them or if they used a brass or other soft metal for a seal
babbah (12-05-2016)
I like the copper washers, you can buy an assortment at your local parts store for a couple of bucks.
babbah (12-05-2016)
Back in the 1960's most cars used a copper or copper-clad gasket/washer for sealing. In the 1970's I know that GM went to the white nylon type. GM Part Number #3921989 (box of 20).
Larry
Larry
babbah (12-05-2016)
I see that there are copper oil pan washers with rubber centers to seal the oil drain plug.
What size do I need for the 437 oil drain plug?
The diameter of the plug that I need?
The Fel-Pro part number for the nylon washer is 70822. The drain plug is a crush-type seal, therefore the gasket needs to be nylon, copper, aluminum (or other soft material) to conform to the shoulder of the drain plug and mating surface of the pan. I suspect the original-issue gaskets were metal, and nylon emerged as the service part later in time.
babbah (12-05-2016)
Larry
This is an original 3866916 magnetic drain plug for 65-66 and many 67 big blocks.
