Headlights
Old 11-22-2016, 12:14 PM
kolsen911
kolsen911's Avatar
Default Headlights
What about headlight upgrades Drove mine first time at night and lights seemed dim?
Old 11-22-2016, 12:27 PM
66BlkBB
66BlkBB's Avatar
St. Jude Donor '13-'14-'15-'16-'17
Compared to the newer lights out there now they will appear dim. I am not sure that an upgrade is possible. Someone else might know. I think the older wiring will complicate things. I haven't driven my car at night for a long time. I did upgrade to Halogen lights on the high beams but was never sure what I could do with the low beams. Since I didn't run the high beams for any extended time I felt the Halogen would be OK. Lets see what others say!!!!
Old 11-22-2016, 12:30 PM
jimh_1962
jimh_1962's Avatar
2018 C1 of Year Finalist
relays
https://www.corvetteforum.com/forums...erheating.html
Old 11-22-2016, 12:31 PM
Gary's '66
Support Corvetteforum!
Gary's '66's Avatar
I put halogen bulbs in years ago. Never an issue and helped quite a bit. There's ways to go brighter, but they're a cheap, cost me around $50.00 for all 4, and easy upgrade. Also a solid state regulator, another cheap upgrade, keeps them from oscillating back and forth from bright to dim the way the mechanical one does.
Gary
Old 11-22-2016, 12:51 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Sylvania H5001 and H5006 will work IIRC and not cause any over current issues; if your lights are still dim it could be old wiring/corroded connectors. As suggested, many add relays to get full voltage to the headlights and to reduce current load at the dash switch.
Old 11-22-2016, 01:37 PM
SDVette
SDVette's Avatar
Received 1,295 Likes on 560 Posts
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
If you are running incandescent bulbs, halogens are a big improvement for very little cost/effort. They are plug-and-play (draw the same current as incandescent) but much brighter, and require no mods at all.
Old 11-22-2016, 03:03 PM
survivor66
survivor66's Avatar
Just replaced my date correct T3s this morning with EIKO halogen, hi/lo only. Rated 12.8 v and 35/35 watt. At $11 each, I can save the T3s for judging and not worry about hunting the world over to find ones that work, and pay out the nose. Plus I can safely drive home from shows now that it's dark at 6pm. I never need the high beams so left those T3s alone.
Old 11-22-2016, 04:20 PM
Frankie the Fink
Army
Do yourself a favor and clean around those T3 electrodes with some lacquer thinner and then seal them with clear silicone. Because if they ever suck the tiniest amount of air they'll pop like a flashbulb the first time you use them. Like for judging ops check
survivor66 (11-24-2016)
Old 11-22-2016, 06:13 PM
mrg
mrg's Avatar
Halogens powered through relays really wakes the lighting system up. Great night driving safety improvement.
​​​​​​​John
Old 11-22-2016, 06:55 PM
Bluestripe67
Bluestripe67's Avatar
Received 2,127 Likes on 1,466 Posts
I put Helle H4 lows and Sylvania Halogen highs in my '67 at least 30 years ago w/55w bulbs. Major light improvement with rewiring. Never have had a bulb burn out. Not cheap, but very good lighting. Dennis
Old 11-22-2016, 07:06 PM
Kerrmudgeon
Kerrmudgeon's Avatar
Received 4,583 Likes on 2,157 Posts
C1 of Year Finalist (appearance mods) 2019
Me too, first thing I do on my old cars.....H4, or similar. Even my 56 Belair has them. I can see clearly now.........
Old 11-23-2016, 03:30 PM
vettepoor
vettepoor's Avatar
I'm wanting to upgrade lights on my 57, and I see that NAPA has two different halogen - type bulbs. One is listed as a "Bright light" and other as just regular halogen. Anyone know if both will work without relays? I still am running generator on my car and would like brightest lights possible without rewiring anything.
Old 11-23-2016, 03:46 PM
SDVette
SDVette's Avatar
Can you post the part numbers?
I took a quick look at NAPA website, but it's hard to tell what you are referring to.
Old 11-23-2016, 03:55 PM
vettepoor
vettepoor's Avatar
NAPA numbers are LMP H6024 BL (bright light) and LMP H6024 for standard halogen. These numbers came up when I entered 57 Corvette. The bright light versions are listed at $17.49, standard are $10.99 each.
Old 11-23-2016, 05:36 PM
SDVette
SDVette's Avatar
Well, the specs seem wrong on their website.. they claim:
6024 35K / 27K candlepower, 60W / 35W
6024BL 28K / 24K candlepower, 65W / 55W
Which says that the 6024 would be brighter for both hi and low beans, and draw less power. So why would anyone buy the BL version???
I'll yield to the experts... but I suspect BL version @ 55W might be too much power for standard wiring on the low beams.
Old 11-23-2016, 05:48 PM
vettepoor
vettepoor's Avatar
Yes, I was thoroughly confused as well after reading their specs.
I'm hoping to hear from someone who has tried these. Also wonder how these compare to the "H4" designation for halogen lights.
Old 11-24-2016, 11:34 AM
Bluestripe67
vettepoor you have e-mail!
To Headlights
Old 11-24-2016, 11:10 PM
C2 Hot Cam Guy
C2 Hot Cam Guy's Avatar
Default bulbs
Ge sells a replacement thats 30 per cent brighter 16$ each they are great
Old 11-25-2016, 01:02 AM
babbah
babbah's Avatar
Leds
Old 11-25-2016, 01:47 PM
NightshiftHD
NightshiftHD's Avatar
Like Jim and Frankie said, beef up your wiring and use relays. Full power at the bulbs (whatever you choose). Bill
Quick Reply: Headlights
