Half-Shaft Gap
Half-Shaft Gap
Correct me if I'm wrong but there shouldn't be a gap this wide for my half-shaft (driver's side) should it?
58n65
58n65
Is there a rebuild video or instructions for this? The half-shaft (yoke to diff.) gap on the passenger side is about a 1/3 of this.
Okay, I seen a picture of a yoke with the snap ring. How on earth do I put a new snap ring on? Do I have to open the differential up?
Thanks,
58n65
Thanks,
58n65
Received 1,122 Likes
Is there a rebuild video or instructions for this? The half-shaft (yoke to diff.) gap on the passenger side is about a 1/3 of this. Okay, I seen a picture of a yoke with the snap ring. How on earth do I put a new snap ring on? Do I have to open the differential up?
Thanks, 58n65
Thanks, 58n65
After the rebuild I have .025" and .035 in and out play on the new shafts.
Joe
You can see the grooves where the snap rings should be. This is a rear I rebuilt for my 64 and the snap rings were both off allowing the shafts to move in and out. Notice how mushroomed each end of the shaft is.
Joe
Joe
BTW, my family, me, and several friends just got back from New York. Had a great time....seen the Statue of Liberty, went up the Empire State Building, my daughter skated at Rockefeller Center, went to Trump Tower and actually met Kelleyanne Conway (daughter has a selfie with her), and MANY more things.
Thanks,
58n65
Thanks,
58n65
I wasn't aware of this until another thread not too long ago but apparently there are various thickness C-clips that can be found to fine tune in the resulting half shaft play. If new yokes get it within reasonable play I'm not too sure how important it is for the average street driven car since the load of the suspension normally pre-loads the yoke against the center pin
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
If you're going to tear it down to that level you might as well check out the rest of the rear end as well. These days it seems that most guys just order a rebuilt from a few reputable rebuilders. We ordered one from Texas? Differentials last summer for my bud's 68. And you can pick any ratio you want that way.
Thanks,
58n65
Thanks,
58n65
Can anyone positively identify the diff. for me? The number on the front side is 3876476-N and the number on the back side is 3871376.
And it has the red plastic tag that reads USE POSITRACTION DIFF LUBRICATION ONLY.
Thanks,
58n65
Thanks,
58n65
Here is Toms corvette differential parts. I did the 1350 vette axle setup and used the correct 30 spline posi spider gears and steel bearing cap.
http://www.tomsdifferentials.com/201...Pages14-23.pdf
What numbers and letters are stamped on the bottom side of the rear case?? That will tell us more.
Larry
The stamped information is what it is 'supposed' to have and does not mean that is what you have.
Simply spin the wheel ONE full revolution and count the number of times the pinion spins...that will tell you the axle ratio. So 3 full turns and a little more than half of a turn would be 3.55:1
I posted photos of it sometime ago...but if you replace your side yokes...make sure you also replace the center carrier pinion shaft where these side yokes contact and spin on....because it can wear also.
I have also repaired rear differential where I had to replace the case itself due to the side yoke wore down so much that the dust cone on it actually ate into the casting where the outer grease seal for the side yoke goes and ate it up so much there was no way to install a new seal...nothing for it to grab onto and hold.
DUB
DUB
DUB
DUB
Larry
The numbers look like "AM 6 15 66" or it could be "AM 6 151 66". It's hard to see since it's installed and I was in my church clothes trying to crawl under there....The wife will kill me for it but oh well.
Thanks,
Dex
DUB
DUB
I can do that once I've removed it. That's the worst part....removing it again. That leaf spring is a headache.
Thanks,
Dex
